Thread: Circupool RJ60 or RJ60+ (or other)
    Jun 2014
    Phoenix AZ
    88
    I have decided to take the plunge and buy/install a SWG for the upcoming season. After much research here and elsewhere, I am leaning towards either the Circupool RJ60 or RJ60+.
    RJ60: 3.1lbs CL/day, rated lifetime of 11500 hours, 5 year limited warranty for $999.
    RJ60+: 3.1lbs CL/day, rated lifetime of 15000 hours, 7 year limited warranty for $1099.
    I decided on these to get the biggest SWG on the market at the best price.
    Anyone have a Circupool RJ or RJ+ and can share their experience? And is the PLUS version worth an $100?
    Also any other comparable SWG to consider instead?
    Thanks!
    20K In-ground Pebbletec Pool with Spa and Waterfall; Pentair CCP520 Cartridge Filter; CircuPool RJ60+ SWCG; Paramount PCC2000 Infloor Cleaning System; Jandy Aqualink PDA-RS8 Automation
    Oct 2015
    San Diego, Ca.
    825
    Re: Circupool RJ60 or RJ60+ (or other)
    oops
    35,000 Gal. - 40x20x8 - Plaster - SWG Pentair IC 60 - Barracuda G3 Vacuum - Hayward c1750 Cartridge Filter - Blue Torrent VS 1.5hp pump - Pool is 45 years old.
    "I'd build a deck over my pool if I didn't have a SWG"
    wilkj1's Avatar
    Nov 2017
    okc/okla
    121
    i just copied this from my thread im doing the same thing and looking at circupool rj60 +
    Re: is a ic60 enough for my pool
    Jimmie,
    A new salt cell would look perfect in there!!!... I am a highly biased Pentair kind of guy, so you would think I would recommend the IC60... Well, if you had an automation system I would... But, without an automation system I would look at CircuPool salt cells... the IC60 puts out 2.0 lbs. of chlorine a day... For the same basic price you can get a CircuPool that will put out 3.0 lbs. per day...
    Here is a clink to a comparison... Compare and Review Saltwater Chlorine Generator Prices and Features
    If you have your heart set on the IC60, it meets our recommendation of being rated for at least 2 x the volume of your pool, so you are good to go..
    I can't say enough good things about saltwater pools... Just keep in mind you still have to test and maintain your chemical levels... Don't let the ease of use lull you into a false sense of security...
    Thanks for posting,
    btw where did you get the prices from ?
    Jimmie...28.5 k inground plaster/quartz, 36'x16' 8.5 deep end dive rock 7x10 tan ledge 10" deep ,build date 11/16 open 4/2017, pent intelipro variable...pent.booster/cleaner bot** named george ** pentair s8m150 cartridge.. intellibrite controler(first automation) so i can stop guessing what color lites are , rheem raypac heater, circupool rj-60 plus,16 mil solar cover, TF100 /speed stir /Taylor K-1766.
    BasicTek's Avatar
    Oct 2016
    Lake Mary, FL
    795
    Quote Originally Posted by wilkj1 View Post
    You actually copied the site with prices in Jim's link
    Choose the size below the 60 then select $1 upgrade, so essentially you are paying the advertised price of the unit below what you want.
    -Tim-
    Pool: 86 gunite/plaster screened IG 12K 14' X 29', Hayward 120 sq ft cartridge filter, Pentair Intelliflo 2 VST, Hayward SwimPure 40K SWCG, Hayward Poolvergnuegen autovac,
    Heat: 280 sq ft Ultrasun solar Panels, Pentair Solartouch Ctrl, (solar cover and reel)
    Tests: Taylor K-2006C & K-1766 w/ speedstir
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,420
    I have had an SJ 45 for over 3 years now, I have also installed an SJ 40 in a friends pool and an SJ20... The SJ40 and 45 are rock stars, they have never had a problem keeping a clear pool all summer long with multiple different uses and people.. On 15,000 Gallon pools, we have never had to run them over 10 hours a day even during Aug in OK...
    The SJ 20 running 24/7 on a 8500 gallon pool has issues in AUG on a pool that gets lots of tree and bug junk in it.. I am going to install an SJ40 in it so I do not have to worry about it ( I did this install as a test of the SJ20 ) This pool is probably the worst that a SWG would have to go through, it did keep up until the end in AUG
    That being said I have not done official tests on them nor do I want to..
    The RJ and the RJ+ are much nicer units with just about every option that more expensive units have and they have much higher output's.. With that said I have not used one nor installed one so I can't comment on them.. I can say that Circupool has a great warranty department along with great troubleshooting when you call..
    Circupool is also a great brand if you are installing yourself, they will not void the warranty like all the others will do
    I can not say enough GREAT things about DiscountSaltPool, they are great to work with, have very knowledgeable people working there and will help with every portion of the install.. And the $1 dollar upgrade is a awesome option
    I hope this helps
    wilkj1's Avatar
    Nov 2017
    okc/okla
    121
    Quote Originally Posted by cowboycasey View Post
    I hope this helps
    Awesome thank you cowboy and you too Tim. 1$ upgrade looking into that right now
