Thread: Copper Plumbing with SWG
    Mar 2018
    Los Angeles/CA
    1
    Hi! I am moving and we currently have a salt water pool. Both my son and I have sensitive skin and the salt water works great. Anyways the new Pool has copper plumbing. Do we need to replace the plumbing to have a SWG installed and what’s the cost for something like this?
    31,199
    Re: Copper Plumbing with SWG
    Welcome to the forum
    Control your pH carefully (always in the 7's) and your pool and the copper pipes will be fine
    JoyfulNoise's Avatar
    May 2015
    14,225
    pH control is important to ensure long life of copper components. However, when copper pipes are present, you must consider galvanic corrosion issues as well. In this situation, proper bonding of ALL metallic components in the pool and around it is critical not only for personal safety (electrocution hazards) but also galvanic corrosion.
    Can you please post more information about the pool? Size & construction/surface type, other equipment at the pad (heaters, lights, etc) and in the pool (ladders, diving boards). Also, have you had this pool inspected and so you know of it is properly bonded? Is there a concrete deck around the pool? Is there rebar in that deck and is it bonded to the pool?
    Matt
