Thread: Intelliflo VS3050 control panel issue
    Mar 2018
    Pleasanton/CA
    3
    Thanks in advance for your help!
    Can anyone validate for me that a 350721 drive assembly will work on a Intelliflo VS3050 (011013). The original part I believe is a 350521. Is there any customization for using the newer replacement?
    Appreciate your help!
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    35,036
    Re: Intelliflo VS3050 control panel issue
    I have a call in to someone that might know. Hold on a bit while they get back to you.
    InyoRob's Avatar
    Feb 2017
    Longwood/FL
    101
    Hello Airgar - I put a call in to our Pentair rep to confirm the correct drive assembly. I'll come back and post as soon as I get a response.
    InyoRob's Avatar
    Feb 2017
    Longwood/FL
    101
    We confirmed with Pentair that you can use the new drive (350721) on an older motor.
