Results 1 to 16 of 16
Thread: pool water not like before
    Jan 2017
    sydney, au
    14
    Hi all,
    I have a saltwater pool. I've been mostly happy with it. Lately, the water is not nice. By that I mean, when the water goes up my nose it feels yucky. I didn't have this problem before. Before, it was like swimming in the ocean. Could it be one of the following:
    -a new saltwater chlorine generator that I installed?
    -a different brand of salt to the one I used before?
    -fine dirt on pool floor that I should vacuum to waste far more often?
    Much Thanks
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,872
    Re: pool water not like before
    Nikica,
    I would assume it is more likely algae... That fine dirt, may not be dirt...
    We don't like to guess, so what I need from you are the following chemical levels..
    FC
    CC
    pH
    TA
    CH
    CYA
    Salt
    Yucky how?
    Is the water cloudy?
    Is the water crystal clear and sparkling?
    Is the water blue or some unusual color?
    Do you have algae?
    Does the water taste different?
    Does the water feel different? Maybe slippery or otherwise different?
    Did you add borates?
    Can you list all recent chemical additions including exact product chemical name and brand?
    Support the site
    Jan 2017
    sydney, au
    14
    hi all, I'm certain that this is not algae, i really wish it was. I've shocked the pool numerous times hoping that it was algae. Th dirt/dust at the bottom accumulates because it is too fine for the sand filter. The water is yucky when it goes up my nose, feels yucky and you don't want it going up there again. It feels like there's something in it, which makes it uncomfortable when going up your nose. I've also asked my nephew and he too said the same thing, that it's not like it was once before. Before, it was like swimming in the ocean. Clearly, something has changed. I use two chemicals in my saltwater pool like most people. I use the bioguard brand and the two are Lo and Slo, and Balance Pack 100. I've also used something only in the last 6 months or so called extreme burnout instead of liquid chlorine. Could it be that? The link is here:
    Burn Out Extreme - Poolside
    The water is clear. Haven't added borates to my knowledge. Water is not cloudy. Water is not slimey.
    I'm thinking that it could be the granular shock? I never had this problem before trying that product. Or not vacuuming often enough?
    I'll post some numbers up in a day or two (the numbers will be good I believe).
    Cheers
    PoolingAround's Avatar
    May 2016
    Katy, Texas
    214
    Hmmm, i only ever have to add acid and bleach so something tells me those other products could be the culprit.
    18k gallon, 20x32, salt IC20, gunite with quartz finish, raised spa with overflow, flagstone coping, moss rock waterfall, Pentair Intelliflo variable speed pump, Pentair Racer, Pentair pool pump, cartridge filter, heater, etc., acid dispenser.
    TF-100 kit for sparkling clean water.
    Do you have a picture of the dirt?
    Support the site
    triptyx's Avatar
    Apr 2016
    1,485
    Let's come full stop here.
    Without a full set of testing numbers, as requested above, nobody can say whether it is algae or something else.
    You've been shocking repeatedly and using trichlor, both of which likely added large amounts of CYA to your pool. Higher CYA means you need more chlorine to prevent algae and bacterial buildup. You say you're sure it's not algae - without proper testing, you don't know if it is or not - and nor do we.
    Please provide us with a full set of testing numbers in the format requested by Jimrahbe above, and we'll provide you with the solutions you need to have a sparkling, comfortable pool to swim in. Meanwhile, stop with the burnout and other solid chlorine products and start using liquid chlorine or plain, unscented concentrated bleach to avoid further CYA increase while we figure this out.
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
    Donldson's Avatar
    NW Ohio
    3,250
    The shock you are using is trichlor powder (probably with a bit of baking soda to counter the extreme acidity of trichlor) which will raise your CYA level. If you have been using that regularly then your CYA level may be too high for the FC level you are maintaining to keep up. Unfortunately it sounds like you are relying on pool store testing, which we have found to be extremely unreliable, so we won't be able to tell you much based on the numbers you return with. It's strongly encouraged that you do your own testing with either a Taylor K-2006 or an equivalent FAS-DPD kit from Clear Choice Labs.
    On a probably unrelated note, Lo 'n Slo is sodium bisulfate. Using this product adds sulfates to your pool which can build up and reduce the life of your salt cell. We really recommend using muriatic acid to lower pH, especially in salt pools. Also using both Lo 'n Slo and Balance Pack 100 is an old pool store trick to rip you off. They want you to keep your TA high but with an SWG that causes your pH to rise. So you add acid to lower your pH, which also lowers your TA, so they have you add more Balance Pack and keep you in an endless cycle of purchasing these products. Also Balance Pack 100 is just baking soda with a price premium. Allowing your TA to drop will reduce the pH rise and decrease the amount of acid you need to add to your pool.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath
    When you say "yucky", do you mean like a chemical reaction or do you physically feel something, like a grit?
    Support the site
    Oct 2017
    Mid-Atlantic
    135
    This thread reminds me of my daughter attempting to describe a noise her car is making. LOL
    IG fiberglass 16X36. 14,600 gal. Heyward Pro Series S270T sand filter, Hayward Super pump 1.5 hp, Aquarite T-3 SWG, and Hayward H200FD propane heater. Two Treo LED lights by SR Smith. Two returns, one skimmer. Tftestkit TF-100 water kit.
    domct203's Avatar
    Jun 2015
    CT
    3,959
    Sandfilters are more than capable of filtering out visible particles, you most likely have the beginnings of an algae bloom. Algae spores are microscopic. As they start to reproduce, some will die from the chlorine and begin to clump together. Eventually reproduction will overcome death and the algae will clump together while alive (that familiar green cloud).
    Do you own a FAS DPD test kit? and Overnight Chlorine Loss Test would tell quite a tale .......
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Jan 2017
    sydney, au
    14
    hi all, here are the numbers:
    saturation idx 0
    tds 5900 ideal is <2500
    stabiliser 51
    tot chlorine 13.2
    free chlorine 12.9
    ph 8.2
    tot alk 141
    adj tot alk 141
    total hardness 37 ideal is 175-225
    salt 5110 ideal is 5000
    copper 0.1 ideal is 0
    iron 0.2 ideal is 0
    Looks good to me, just needed to bring the ph down.
    Not much is clearer from these numbers as to what it could be.
    Thx
    AftonJeeper's Avatar
    May 2017
    Twin Cities, MN
    1,147
    Have you considered getting your own test kit? None of us trust pool store testing, they are in business to make money and a free test is a good way to get you in the door. Many of the folks on here have reported different results and advice from various stores with the same sample of water. Clear choice labs is the best place to get a quality test kit over there. Here is a link to the salt water pool test kit: Total Pool Water Testing Kit, Salt Water Clear Choice Labs
    Do some reading in pool school when you have a chance. ABCs of Pool Water Chemistry is a good place to start.
    20'x48' 40,000 gal. Vinyl, Pentair Intelliflo 2 VST, Sta-Rite PLM300 System 2 Cartridge Filter, and a Pentair Mastertemp 250 heater all controlled by Pentair Easy Touch with Screen Logic. Dolphin Premier pool attendant.
    I've got iron stained well water. TF-100 and Speed Stir, Lamotte 3017-G for Borates
    Jan 2017
    sydney, au
    14
    With that kit or similar, how do I know how much chemical to put in? So, I look at the online calculator here, can I just grab any chemical brand and throw that amount into the pool?
    Thanks
    Jezza's Avatar
    Jan 2015
    Bunbury, WA, Australia
    959
    First things first, you really need to get hold of the test kit from Clearchoice Labs. The numbers will give us a good idea of what your issue is.
    Throwing chemicals into the pool based on some questionable numbers from a pool store at best is what we don't encourage.
    11 000 gallons, IG, Fibreglass, Monarch Sand Filter, Davey Typhoon C100M 1HP pump, Davey Chloromatic Mc16CTO ESR SWG, Davey Pool Wall Climba Robot, Daisy Solar Cover,
    K-2006
    aussieta's Avatar
    Jan 2014
    Langwarrin, Victoria, Australia
    661
    the pool store guesses your ph is high so you should throw this in
    next week they guess something else
    when i first bought my house with a pool
    i was pool stored to several hundred dollars over a few weeks
    then i found tfp
    i had to wait for my kit so still had store test my water
    one time they told me i needed something and i said i had some at home and would add it when i got home
    following week they said it was fine, however i hadnt added anything
    SWG inground peanut shaped eco-bright concrete pool
    50,000 litres 13,000 gallons
    Lincoln Salt Chlorinator, 25 gram cell Sand Filter with glass media
    Taylor K2006-C test kit, Taylor K-1766 salt test, Dolphin M500 pool cleaner
    are you taking care of your pool or is the poolshop taking care of you
