Thread: Acrylic Deck and Pavers
    Mar 2018
    Chandler, AZ
    13
    Hi,
    My pool deck will be 4" thick concrete with acrylic deck topping. This will be 3 feet wide around the pool perimeter.
    The area beyond that will be pavers.
    The question i have is, should the pavers be installed all the way to the deck edge? or should there be a gap ?
    Note that the pavers are installed all the way to the foundation of the house already (post tension slab).
    If there should be a gap between pool deck and pavers:
    1. is this because of the pool deck concrete expansion?
    2. is this because of drainage?
    3. how wide should the gap be?
    4. fill the gap with gravel? or something else?
    My Pool: Gunite; 12,000 Gal; mini-pebble aqua white, Pentair VSF pump 011056; Pentair CCP520 Ctg filter; Pentair intelliBrite 5G color 601001 with controller 600054
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    35,012
    Re: Acrylic Deck and Pavers
    All of the pavers I have seen installed have the pavers going right up to the decking unless they were doing a decorative strip with rocks or grass. care should be used to make sure the correct slope is used on all of it to prevent drainage problems in the pool and house.
    Kim
    Mar 2018
    Chandler, AZ
    13
    Thx!
