Thread: Autospa Actuator with automation
    Mar 2018
    PALM DESERT/CA
    3
    Hi All!
    I'm in the process of installing a Pentair Easytouch PSL4 control system.
    I've got everything working in a test setup, but in looking closer at my equipment it seems the Pentair 24v actuators that came with the control center aren't compatible with the valve actuators in my system.
    The valve actuators that I have are manufactured by Chardonnay of Tarzana CA, and appear to be 120v. The mounting screw pattern don't look compatible with the new Pentair actuators. Looks like the manufacturer may be out of business... pics of the actuator attached.
    Any thoughts on how best to proceed with this non-standard actuator setup?
    Thanks!
    Tom
    Apr 2015
    tucson, arizona
    1,405
    Re: Autospa Actuator with automation
    Probably the best solution would be to cut the old 3-way valves out and install either Pentair or Jandy valves in there place. Your new actuators will work with either valves
    Mar 2018
    PALM DESERT/CA
    3
    Quote Originally Posted by kadavis View Post
    That's what I was afraid of... Thanks!
