Results 1 to 7 of 7
Thread: Jandy PDA control box stuck with some lights and no display
    Oct 2007
    Parkland, FL
    759
    Looked today at my Jandy PDA control box and it just had a couple of lights on. Switched power at the breaker and now the just the auto light is on with no display on the aquapure. I'm assuming it had something to do with daylight savings time as it's been working flawlessly. Any idea how to fix? I vaguely remember this happening about 3 years ago right after we moved in.
    8000 gal diamond brite pool with 650 gal spillover spa, Pentair 3hp VS pump. Jandy Cartridge filter and Jandy Heat Pump. Jandy PDA automation system with 2 Pentair Laminars. SmartPool NC74S Robotic Pool Cleaner.
    Oct 2007
    Parkland, FL
    759
    Re: Jandy PDA control box stuck with some lights and no display
    So further testing the pda shows the Auto light and the aquapure display is completely dead. I checked the test points and it appears no voltage is coming from the aquapure transformer. Would that cause both parts to be messed up? Does anyone have troubleshooting guide for the jandy PDA unit? I have the guides for the aquapure unit.
    Oct 2007
    Parkland, FL
    759
    Bump
    Any ideas?
    PoolGate's Avatar
    Jun 2017
    Damascus, MD
    2,376
    Call Jandy tech support!
    29k Gallon Free Form Gunite Pool, 3 floor returns, 2 wall returns, 1 vacuum pressure port, 2 skimmers, Main drain, Jandy 2.7HP VSP, Jandy JXI400N Gas Heater, Jandy CV340 Cartridge Filter, FusionSoft 1400 SWG, 2 Watercolors LED, iAqualink with PDA, Sheer Waterfall, Rock Waterfall, 9' Deep End w/Diving Board, SunDeck, Polaris 9650iQ, TF-100 - Pool Build - 2017 - Google Photos
    Oct 2007
    Parkland, FL
    759
    LOL, That was a good one. Have you tried that? I have multiple times and they won't talk to you unless you are a pool installer. At any rate, it resolved itself although i'm not completely sure how. I don't know if there is a short or something, as it decided to boot back up and work and then proceeded to intermittantly go on and off until it went back on again and stayed on. A repair place suggested maybe the board is flexing and that is causing the problem, but I screwed it all together again and banged on it pretty well and its still working for now. 150 bucks with some shipping to have it repaired worse comes to worse. I hate Jandy stuff. If I wasn't stuck with it I'd dump it and go with Pentair.
    PoolGate's Avatar
    Jun 2017
    Damascus, MD
    2,376
    Quote Originally Posted by robl45 View Post
    Mostly I get very helpful techs but I did get a real jerk once. One even sent me a free part that upgraded my system to full wireless control ($300 upgrade board). It does sound like you have some sort of short somewhere. Re-seat everything including the far end of the connections (at the SWCG).
    Oct 2007
    Parkland, FL
    759
    You are very lucky when calling tech support. I've called at least 3 times and all 3 times were essentially call a certified Jandy person, we can't help you. At any rate, its working again now and been working for the past couple of days, extremely bizarre.
