Thread: Pump/Filter Recommendations
    Roxbury123's Avatar
    Dec 2016
    Glen Burnie
    5
    I calculated that I need a pump for 33 GPM and 60 ft of head pressure. Hayward has the SP2610x15 pump and S210s sand filter. I may be getting ahead but I see you guys reccomend a 2 speed pump? Also the reviews on the s210s seem pretty bad at least on Amazon. Iíve have the TF starter kit on order and am hoping to get everything ready before the weather breaks to get this black lagoon cleaned up. The pool hasnít been open in about 3 yrs.
    Design: IG 30x15 oval (16k gallons) vinyl pool, 1 skimmers, 2 returns
    Epuip: Pentair Quad DE 100, Pentair Superflo VS 1.5hp
    Water: TBD
    cfherrman's Avatar
    May 2017
    Hays, Kansas
    1,702
    Re: Pump/Filter Recommendations
    At 1.5 hp you will want a 2 speed minimum, the $150 price difference could be saved in one season. I only wonder if it will flow to much, I bet it will be putting out more than 30 gpm so check the head chart.
    A 21" sand filter seems big enough for your pull, but bigger is always better.
    Casey
    Intex 24' x 52" closed for winter 2018, 2 Main Drains, 1 Skimmer, 1 Return, PVC
    1/2 HP Intex Pump 633T w/ Taeglus TA-40 175 lb 19.5" Sand Filter, Auqabot Extreme Robot
    TF-50 and Taylor 2006 Test Kits, Quality Well Water, Fleck 5800SXT Water Softener
    Roxbury123's Avatar
    Dec 2016
    Glen Burnie
    5
    Quote Originally Posted by cfherrman View Post
    The 2 speed is still at 36GPM but it doesnít give a spec for low speed at 60 feet. It has 18GPM at 15 feet. Even though there is no spec will it still have enough pressure to turn the water over? I realize this will take prob 24 hours to filter all the water instead of 8 hours.
    I was on the fence anyway with the filter. Iíll step up to the S270T which should be more than enough. 74GPM and 35,520 gallon turnover in 8 hours.
    Water: TBD
    cfherrman's Avatar
    May 2017
    Hays, Kansas
    1,702
    Run the head loss for your system at 18 gpm, the head loss should be very small.
    Don't worry about turnovers, it's not a commercial pool.
    Casey
    Roxbury123's Avatar
    Dec 2016
    Glen Burnie
    5
    Ok thanks. Itís all ordered.
    Water: TBD
