Results 1 to 11 of 11
Thread: How well (or not well) will salt dissolve in my 57 degree water?
    May 2017
    Lexington, SC
    144
    I just bought 15 bags of pool salt at Lowe's and have been waiting to start adding it since I knew I couldn't generate salt at these temps anyway (my pool temp is 57 right now). I decided to add a bag tonight and noticed that it collected on the bottom. Will this salt dissolve on its own fairly quickly? I'm trying to set expectations for what I might encounter if I go ahead and dump about 10 of the bags in the pool at these temps.
    Thanks!
    Built in Feb 2018, 19K Matrix Vinyl Pool 16x37 (8ft deep end), 1,890 sq ft concrete decking
    Pentair IntelliFlo, Pentair IntelliChlor IC-40, Pentair Triton II Sand Filter, Pentair IntelliBrite 5G Color LED
    TF100 Test Kit
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,906
    Re: How well (or not well) will salt dissolve in my 57 degree water?
    Raw,
    You don't just dump it in and let it sit there... Use your brush and sweep it around a little..
    It take about 30 seconds longer when its cold... Ok, I made that number up, but the cold does not make much difference..
    IC40's will, in theory, generate when the water temp is above 52 degrees... It varies with each SWCG, so if your pool is 57 it probably will work.
    It will take 24 hours before you can get a semi-accurate salt readings out of the IC40.. Don't just go adding more salt just because the IC40 says the salt level is low... double check with the Taylor K-1766..
    And, unless you turn the Cell off and then on, it will only update ScreenLogic every 12 hours...
    Thanks for posting,
    If you have never seen an IC40 initially come on, it will flash a red and green light back and forth for about 5 minutes while it calibrates itself... This is normal operation.
    May 2017
    Lexington, SC
    144
    Thanks for the info Jim! Should I spread the salt evenly around the pool or just dump it all in the deep end and work it with a brush from there?
    TF100 Test Kit
    Jul 2014
    Bedford, TX
    9,906
    R,
    When I'm adding a bag or two, I dump it along one side of my pool and then use the brush to push to toward the other side. It only takes a couple of minutes for it all to visually dissolve. My understanding is that it takes about 24 hours to fully mix with the water.. It will take a little more effort if you added all the salt at once...
    PoolingAround's Avatar
    May 2016
    Katy, Texas
    214
    I added 6 bags the other day (one at a time) and just mixed until i couldn’t see any more salt on the bottom. Make sure your swg is off and let the pump run a full 24 hours before you turn it back on.
    18k gallon, 20x32, salt IC20, gunite with quartz finish, raised spa with overflow, flagstone coping, moss rock waterfall, Pentair Intelliflo variable speed pump, Pentair Racer, Pentair pool pump, cartridge filter, heater, etc., acid dispenser.
    TF-100 kit for sparkling clean water.
    May 2017
    Lexington, SC
    144
    I know I'm probably over analyzing, but I filled up a 5 gallon bucket with pool water, poured some salt in there and have been mixing it vigorously for about 20 minutes and there's still plenty in the bottom Maybe when you say it disappeared visually in a couple minutes, it was still down there but just not noticeable?
    TF100 Test Kit
    Jul 2014
    Bedford, TX
    9,906
    R,
    I use this type of salt... Diamond Crystal 40 lb. Pool Salt-110002702 - The Home Depot
    When I brush it, it turns into a white cloud and appears to disappear pretty quickly..
    And yes, I think you are making this harder than it needs to be...
    May 2017
    Lexington, SC
    144
    I think you're right Jim.... I'm trying to create problems when I don't have any. I have the exact same salt as you
    TF100 Test Kit
    May 2017
    Lexington, SC
    144
    One more curiosity question. If someone leaves a mound of undissolved salt at the bottom on their liner until it finally dissolves on its own, does that negatively impact the liner in any way?
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    615
    I wouldn't even turn the SWG on after adding the salt at those water temps. Save yourself some cell life and use bleach for a few more weeks, until the water warms up quite a bit. Just my opinion.
    Mark
    20'x28' IG, Vinyl, (Sept 2015) 14,900 Gallon, 3'4 to 5'6 deep, Jandy Proflo 1.5 HP, 220v, 2 speed pump, Waterway Carefree 27" 400 LB Sand filter, Digital Nano plus SWG, TF-100 test kit /speed stir. Dolphin Primal x3 robotic cleaner
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,760
    Quote Originally Posted by rawb View Post
    It never caused any problem in my Intex pool. That's all I ever did.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
