Results 1 to 16 of 16
Thread: Shotcrete/gunite
    Feb 2018
    Jacksonville, FL
    188
    Shotcrete/gunite
    Does the shotcrete or Gunite have to sit for a certain period of time before the plaster is done?
    Paige
    16x32 gunite pool. Florida Gem Plaster. Two LED bubblers with 10X6 sunshelf. Salt system... equipment Carvin, says Pentair on the actual equipment? 75,000 BTU heater. Screen Enclosed.
    JoyfulNoise's Avatar
    May 2015
    14,231
    Re: Shotcrete/gunite
    Usually 21 days to cure with frequent watering (depends on weather/temp/humidity).
    Matt
    riley00dog's Avatar
    Nov 2017
    Brisbane, Qld, Australia
    2,185
    Our PB lets it cure for 28 days. We're on day 23. Sigh. Watered for 14. I know some PBs only leave it for a few days.
    3.2 x 6m | inground concrete | ~27,000 litre | 1.2 - 1.8m | salt and pepper mini pebble | SWCG Atral eq35| Viron xt 1.5 HP VS pump | Astral CA280 sand filter | DB3 robot | 2 x LED lights | travertine coping and paving | ceramic waterline tile |
    Feb 2018
    Jacksonville, FL
    188
    Thanks y'all. I was just curious... I am still waiting for DIGGING! should be any day now.... so they say lol
    Paige
    May 2015
    14,231
    I’ve read the first 48hours is the most critical as that is when concrete achieves something like 90% of its strength. After that, it’s just slow curing....I think there’s some structures the Romans made out of concrete that are still technically curing....
    Matt
    Dirk's Avatar
    Nov 2017
    Central California
    4,364
    I've been trying to sell this idea here lately. I get a commission.
    Are you on metered water? Right before the fill (coordinate this with the PB):
    Start with all the water out of the pool (that's how the plasterer's should leave it). Have everybody in your household take their showers, use the toilets, wash the dishes, etc. Then go read your city's water meter and record the number. Start the fill and resist using any water (or if you have to use the toilet(s), keep track of the number of flushes). No showers. No laundry. No watering the lawns, etc. When the fill is finished, go read and record the meter reading (then go to the bathroom)!!
    Calculate the difference between the two numbers, subtract a gallon or two for every flush you snuck in there, and voila! You'll have a very accurate number for pool water volume, which will help you with all your future pool water chemistry adjustments.
    Some meters are in gallons, others are in units. You'll need to know which and do the proper math...
    BTW, we've got another poster here whose PB dumped the responsibility of the fill into his lap. He's got big problems now because he needed to stop his fill for a period of time. Do not stop the fill of your new plaster/pebble pool! You want to fill it as fast as you can, in one continuous shot, to avoid getting any kind of ring.
    Are you going to be taking care of the pool yourself? Do you have your test kit yet? Have you been practicing with it? Now's the time...
    12300 gallon IG pebble, freeform 19x28, 1 skimmer, 3 returns, no floor drains, auto fill. Pentair: EasyTouch PSL4, ScreenLogic2, Indoor Control Panel, Intelliflo 2 VST, IntelliChlor IC40, IntellipH, CCP320 Cartridge Filter, MasterTemp 250 Heater, Rebel Suction-Side Cleaner, IntelliBrite. Solar and cleaner actuators. Heliocol HC-50 8-panel solar heating. FlowVis Flow Meter. Taylor: K-2006 and K-1766 Test Kits, SpeedStir. City/softened water.
    May 2015
    14,231
    Or you can buy one of these -
    Sotera FR1118P10 Inline Flowmeter, Digital, Blue/Black :
    https://www.amazon.com/dp/B00MHKIFG2..._vVCOAbFDWDF89
    It’s both a flow meter and digital totalizer.
    Matt
    Dirk's Avatar
    Nov 2017
    Central California
    4,364
    I used to try to sell my metering idea using a similar meter (like the kind you'd put at the curb). That's how I measured my pool. But they're about $60, so I think that drove 'em away. My new sales pitch only requires a little inconvenience, but no cash. So far sales have not been any better!
    In addition to the meter, I had to buy adaptors for the hose. And then a second hose to reach the deep end (not a good idea to splash water over the side onto new plaster). Then there's the issue of filling fast enough. You could try running two or three hoses together into a meter, and you'd probably get a little better flow than one hose, but not like you will using the street's meter and all your hoses unrestricted...
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,542
    It's a great idea to take advantage of your water meter. You could also take a reading a week or two before the fill, and then get your average daily use before the fill, which could then be subtracted. Just for example, we use around 125 gallons most days, and bigger days are around 150. Our toilets are on recycled water, which would add another 20/25 gallons and garden irrigation (or concrete bonding ) would throw it off.
    12k IG salt; glass beads in plaster; K-2006C, K-1766, K-1106 and CCL test kits; Pentair Eco800 1.2HP VS; Zodiac SWCG 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; Other family pools 10K SWCG and 15K on liquid; PoolMath app subscriber; | Tips for New Members to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    PoolGate's Avatar
    Jun 2017
    Damascus, MD
    2,376
    This is exactly what I did! ~29k gallons!
    29k Gallon Free Form Gunite Pool, 3 floor returns, 2 wall returns, 1 vacuum pressure port, 2 skimmers, Main drain, Jandy 2.7HP VSP, Jandy JXI400N Gas Heater, Jandy CV340 Cartridge Filter, FusionSoft 1400 SWG, 2 Watercolors LED, iAqualink with PDA, Sheer Waterfall, Rock Waterfall, 9' Deep End w/Diving Board, SunDeck, Polaris 9650iQ, TF-100 - Pool Build - 2017 - Google Photos
    PoolguyinCT's Avatar
    Jul 2014
    Connecticut
    2,601
    Quote Originally Posted by PoolGate View Post
    Poolgate - you can’t trust “water company’s” meter.. for an accurate volume count you must fill pool in 1 gallon increments, and measure each by weight. Start pumping!! I’ll lend you a Shinmaywa
    Dirk's Avatar
    Nov 2017
    Central California
    4,364
    Taking a picture of the meter readings is an excellent additional step!
    PoolGate's Avatar
    Jun 2017
    Damascus, MD
    2,376
    Quote Originally Posted by PoolguyinCT View Post
    Yeah I figured that but gotta be no more than + - 10% off, right? The chemicals I put in I base on that volume and I get what I am supposed to get so I think it is close enough.
    Dirk's Avatar
    Nov 2017
    Central California
    4,364
    I think you guys are joking, but just in case... The meter I used to measure my pool volume is accurate to ±1.5%, which is typical for most street meters. In my case that would be less than 200 gallons (so I really shouldn't be bragging that I know exactly how much water is in my pool!). So technically that could throw off levels of chlorine, acid, etc by a bit (well, by 1.5%!). But the bigger issue is the test results, which can vary by as much as 15% (CYA testing is especially bad in that regard). So no matter what you come up with off a water meter it's going to be plenty accurate for pool maintenance, and considerably more accurate than trying to guesstimate how much water is in a free-form pool!
    Jul 2014
    Connecticut
    2,601
    Yes - sick senses of humor.
    Dirk's Avatar
    Nov 2017
    Central California
    4,364
    Well, you did use a smiley...
    But you guys did bring up an important concept, about accuracy. The tests and the water volume can only get you in the ballpark because of their combined accuracy factor, so you still have to pay attention to how your water and surfaces are actually doing. You can't ignore real-world conditions just because you "know" you have the exact correct level of this or that. I just went through this. I know my water volume, and I know I poured in a gallon or CYA. But the pool is still acting (and testing) like there's not enough CYA. So I have to add some more CYA in spite of my measuring efforts...
