Only had the Tiger shark one season. Works good but the belt drives will eventually become jammed on the brush rings and stop working. Any fix or way to tighten this? The teeth are good and I don't think I would need new belts after one season.
Unfortunately not. Replace the belts, check to make sure the wheel tube bearings haven't exploded too. If the bearings go out the tension on the whole belt is lost.
