Thread: Hayward Tiger shark belts jam
    aceflyerswa's Avatar
    Apr 2017
    Houston TX
    4
    Only had the Tiger shark one season. Works good but the belt drives will eventually become jammed on the brush rings and stop working. Any fix or way to tighten this? The teeth are good and I don't think I would need new belts after one season.
    21,500, IG, Plaster, DE Filter
    Hayward Tristar VS, Pool build 6/16/17
    Taylor k-2005, SWG
    Jul 2017
    Massapequa, NY
    302
    Re: Hayward Tiger shark belts jam
    Unfortunately not. Replace the belts, check to make sure the wheel tube bearings haven't exploded too. If the bearings go out the tension on the whole belt is lost.
    Aqua Products Certified Premier Service Technician, Maytronics Elite Service Technician, Hayward Authorized Robot Technician. I also dabble in pump, filter, and automotive repair.
    Need help choosing a Dolphin? Check out my thread on the features of each model.
    Apr 2017
    Houston TX
    4
    Update, I bought new belts and it's doing the same thing! These belts last about 2 months. Do not buy this piece of Junk!
    Taylor k-2005, SWG
