Thread: school me on CSI please
    Oct 2017
    Richmond, TX
    52
    Ladies & Gents,
    Been reading a lot of posts regarding CSI and been "modeling" on the pool math app to see what impact CSI in what way, but still struggle a bit to understand how I can get my CSI number closer to 0.
    Here are my numbers from last night:
    FC 4.5
    CC 0
    pH 7.5
    TA 80
    CH 225
    CYA 60 (previously at 40, added stabilizer two nights, so that number might go up slightly over the week)
    Salt 3800
    Temp 71
    CSI -0.57
    So the obvious one is that CH should come up a bit. But even if I put it right in middle of target at 400 on pool app, it only moves the CSI to -0.330. Raising pH also appears to lower CSI quite a bit (according to my playing with pool math), but would need to be at over 8 to get to 0 CSI, so not really desirable. All other results appear to be in range, so I'm not clear what lever to pull to assist getting CSI to as close to neutral as possible. Or should I just not worry about it too much if all else is in range?
    Thanks in advance!
    15' by 30' pool with a 6' interior spa / 3 Brilliant Wonders LED descents / Hayward 3HP EcoStar VS pump / Hayward SwimClear 425sqf cartridge filter / Hayward H-Series 400KBTU heater / Rainbow Inline Chlorination Back up system / Hayward T-Cell 15 SWG / Hayward OmniLogic Ultimate App Driven Automation Computer / Hayward Neverlube Valves / Hayward Pool Lights / Hayward TigerShark cleaner / TF-100 test kit
    triptyx's Avatar
    Apr 2016
    1,485
    Re: school me on CSI please
    That doesn't look right to me.
    Putting in the same numbers, I'm getting -.56, which is close to the bottom of where you want it.
    Colder water has a significant effect on this number. Leave your CH alone, but let the pH come up to around 8 while the water is cold. As it warms up, you can start targeting around pH 7.5.
    In general, especially when the numbers are very close to suggested (as yours are), keeping the pH between 7.2 and 8 will be just fine for your plaster. Where CSI really starts coming into use are in places such as the desert southwest or where the water is very hard and people are trying to minimize scale with CH numbers in the high 100s to 1000 or more.
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
    Oct 2017
    Richmond, TX
    52
    Thank you so much Triptyx!
    You are absolutely right, my result was -0.57, typo on my end.
    triptyx's Avatar
    Apr 2016
    1,485
    No worries! If you're worried that you're too close to -.6, just let the pH naturally rise to around 8 and then maintain it there. I believe that takes you to around -.08 (if memory serves) which is darned near balanced at that water temp.
    Does your fill water have a reasonable amount of calcium in it? If you can expect evaporation to cause that CH number to go up over the season, it's fine just where it is. If not (or your fill water goes through a water softener), you might consider adding a little calcium to the water to assist that CSI number a hair.
