Thread: What flex pvc hose brand?
    uxbridgechris's Avatar
    Jan 2018
    uxbridge, Ontario Canada
    560
    Ok folks, I do not want a war here between the flexible pvc hose lovers and haters. Lol
    There are a few brands of this on the market all made in the USA. Tiger flex, flexpvc.com brand, hydromaxx etc. Is ther one stand out brand from your experience? Cheers
    Blue Hawaiian “Wellington” FG pool 6500 Gal. Raypak 266 NG Nickle plated, 3/4hp Hayward super pump, Heater Reader wifi / app controller. Pentair 420 sq' cartridge filter. Hayward 25k SWG
    Pal LED pool lighting. Jandy K-1100 Electronic Autofiller Build thread here: 2018: Fiberglass install uxbridge ointario
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    35,032
    Re: What flex pvc hose brand?
    I will as my go to guy to step in. He is a master pool builder should should know if one brand is better than another.
    So why do you want to use flex hose? Just seeing what you are thinking so he has the whole picture.
    Kim
    Jan 2018
    560
    You are bad Kim. That can of worms is better left sealed. lol
    Builders here use it. I do not like the thought of rigid couplings heaving up and down, year after year, stress on bulkhead fittings too.
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    Flexible PVC has a tendency to crush after years of being buried.... That aside tiger flex is as far as I know an expensive but highly regarded brand of flexible PVC. All PVC has UV stability issues and will harden over time. A simple coat of paint can help delay any UV related hardening issues.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    Jan 2018
    560
    FYI, the only place my flex pvc will be out of the ground will be in the equipment shed. There will be no sunlight hitting it.
    Also, my flex lines will be sitting on 1" rigid insulation (that insulation will be sitting on 6" of HPB) Then, a 2 pound spray foam with be sprayed over top covering the remainig 3 sides and the rigid foam.
    Jul 2012
    Tallahassee, FL
    35,032
    Well that will be as close to solid pvc as you can with flexible!
    LOL I just like to make sure I understand the whys and hows when someone is thinking outside the box or against the norm. Not everyone is as "plan ahead" as you are or as "think it through" so I feel I need to make sure it has been thought out and the pros and cons are thought through. You never know who will find this tread in the future. It can be used as a learning thread for them on what to do or not to do.
    Kim
