Thread: Brand new pool: To vac or not to bot vac... that is my question
    Feb 2018
    Houston, TX
    35
    Hi all!!!
    Thank you all who have been so helpful with advice and suggestions. You are all wonderful!!!
    As a brand new IG pebble pool and spa owner, I have many questions.
    How long should you wait before using the robot vac??? Iíve been told different time frames and donít know which to go by.
    Any help appreciated!!!
    Thanks.
    19,000 gallon free-form, IG gunite mini-pebble pool and spa; cartridge filter; Hayward 400F DN, SP 3202VSP, C 7030; brand new pool 2/1/2018, Houston, TX; using Taylor K-2006 FAS-DPD tests.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    35,040
    Re: Brand new pool: To vac or not to bot vac... that is my question
    30 days is the standard time. Until then you can and should use a manual vac without wheels. I think every pool should have a manual vac as you never know when you want to do a spot clean. I like this head: https://www.amazon.com/U-S-Pool-Supp...ly+vacuum+head
    Kim
    Feb 2018
    Houston, TX
    35
    Thank you!!!
    triptyx's Avatar
    Apr 2016
    1,485
    Quote Originally Posted by kimkats View Post
    Kim
    hmmm....if that will fit my Kreepy hose, it would be highly valuable for vacuuming the spa....
    Thanks for the pointout Kim!
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
