Thread: My Cleaner is still picking up loose pebbles
    Aug 2017
    katy,tx
    15
    How long after a new build should this happen? Every time I run the cleaner I have a handful or so of loose pebbles in the basket when I clean it out.
    Gunite 12x30, 6x6 spa, Northshore Caribbean Satin Matrix, travertine coping,sundeck, jandy flo pro 2hp 2 speed, jandy 460 filter,jandy 400k btu heater, 9350 robot
    Reddogdan's Avatar
    Sep 2013
    Mansfield, Texas
    243
    Re: My Cleaner is still picking up loose pebbles
    Our installer told us 4 years
    14.3k, 3 1/2-5 1/2, IG, Pebble Wet Edge Northshore Tahoe, Jandy 4 cartridge, Jandy 2hp variable, Pentair 320 inline chlorinator fed by a Stenner, Polaris 280, K-2006 test kit, Built 9/13
    Fill water: TA=90, PH=70, CH=90
    Aug 2017
    katy,tx
    15
    Quote Originally Posted by Reddogdan View Post
    wow that seems like a long time but i guess its normal then.
    Reddogdan's Avatar
    Sep 2013
    Mansfield, Texas
    243
    The amount over time will reduce. It's just billions of tiny pebbles some of which arebarely stuck down. Brushing, and pool activity knock off a few more until they get to the solid level.
