Thread: Do I need to replace water?
    Jan 2017
    Tucson Arizona
    6
    I have just tested my water today, and I am wondering if I need to empty out some water and replace it.
    my reading are as follows:
    FC: 4.0
    CC: 0.0
    pH: 7.2
    TA: 70
    CH: 800
    CYA: 80
    CSI: -0.38
    Pool Temp: 60
    At the moment the SWG is off and I have been using Walmart 8.25% bleach for the chlorine levels.
    Thanks for any input.
    11,800 gallons in ground gunite pool, Pentair Intelliflo 2 VST pump, Pentair Intellichlor SCG IC40 with Intellichlor power center,
    Pentair Clean & Clear Plus Filter NSF-50, Intermatic T104R timer for Intellichlor SCG IC40, TF-100 test kit, K1766 salt test kit, Dolphin S300i robot.
    Solar-Breeze NX2 skimmer
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,872
    Re: Do I need to replace water?
    m,
    I'm not sure why you would??? Other than your CH being a little high, I don't see any issues..
    Many AZ pools owners have high CH.. I do suggest that you let your pH hang out at the upper end of the range, like 7.7 or 7.8, which should bring your CSI closer to zero..
    Why do you believe you need to drain???
    Jan 2017
    Tucson Arizona
    6
    Thanks for the reply Jim R, I'm a bit concerned about the high CH, but I guess I don't need to be is that correct?
    I will get the pH up to around 7.8.
    Jul 2014
    Bedford, TX
    9,872
    m,
    You don't need to do anything to increase the pH... I am just assuming it will increase on its own... When it does, just try to keep it around the upper end. When it gets to 8.0, just drop it back to 7.6 or 7.7... don't take it all the way to 7.2...
    Your CH is fine for being in AZ...
    Jan 2017
    Tucson Arizona
    6
    Thanks for the advice Jim R,
    I appreciate it.
    cfherrman's Avatar
    May 2017
    Hays, Kansas
    1,707
    If you are going to mantain your csi and manage the oh as directed above, run your check untill you cannot manage your csi anymore, you still have ch room
    Casey
    Intex 24' x 52" closed for winter 2018, 2 Main Drains, 1 Skimmer, 1 Return, PVC
    1/2 HP Intex Pump 633T w/ Taeglus TA-40 175 lb 19.5" Sand Filter, Auqabot Extreme Robot
    TF-50 and Taylor 2006 Test Kits, Quality Well Water, Fleck 5800SXT Water Softener
