- May 23, 2015
- 24,381
- Plaster
- Pentair Intellichlor IC-60
You are correct. I just think about the things that could go on in a hot tub- MORE BLEACH PLEASE!!
If I can get over that, then I would like to see it hooked up. Most are already disconnected. “Ran when parked” comes to mind...
I’m good with a Sams tub. I just need to investigate parts availability. Maybe they are universal to some degree
18x36 vinyl liner , Hayward Sand Filter, Maxflo VS pump, Hayward VS Omni automation, Rheem 115k Heat pump, Colorlogic LED. Dolphin 400 robot. Build date: Spring 2018.
All hot tubs, new or used, need to be purged with Ahh-some. Tub manufacturers must pressure test them before distribution and they never clear all the water out of them. So you get a tub with stagnant water in the lines as well as greases and lubricants in the pipes. This requires a chemical flush and Ahh-some is what TFP recommends most.
