I've decided to replace my old and failing PacFab DE Filter and 2HP single speed pump.
For the upgrade I purchased
- Pentair 011018 IntelliFlo 3HP pump
- Pentair FNS Plus 60 Sq Ft DE filter (upgraded from 48 Sq Ft)
- Pentair 261152 2" Multiport Valve
- CMP Hi-Temp Unions 2"
- Eaton CHSPT2ULTRA Surge Protector
I thought about adding (but didn't)
- Flowvis
- Switching to Chlorine
Below is a photo of my current system before i make the replace
- Pic 1 - total system
- Pic 2 - Close up of existing pump filter and connection to main pump suction
- Pic 3 - Waste line fed by backwash
Here are my questions
1) Should I add a FloVis and if yes, why and where do I install it in my system?
2) If you look at picture #2 i assume the white stuff around the grey PVC pipe and black PVC of the pump is glue and I dont see a lot of space to cut the PVC to remove my pump and add more PVC - Looking for plumbing advice
3) Picture 3 shows the waste line - there is an orange cap in the middle of the line with holes in it. When i do a backwash, water shoots up in the air about 15 ft and makes a mess (as you can see all the DE around my system from a recent backwash). Why is this cap with holes there? Can i remove it
4) Any recommended how to videos for my install?
5) Any reason why I should spend another $1,500 to switch to salt water - i find buying chlorine at costco rather easy
6) Any additional advice on my upgrade?
I appreciate all your help
Thanks
John
- Flowvis
Thanks
John
