Thread: Winter/liner damage
    Mar 2018
    West Deptford NJ
    2
    Winter/liner damage
    Need advice...
    Closed pool in September. Turns out there must be a leak in the liner and water level can not be maintained. Pool walls are buckling and one frame post is leaning in about 6 inches.
    More additional winter weather is fast approaching. Is it best to remove the cover to take pressure off the walls for the approaching snow?
    24 round above ground pool
    9 years old
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    34,995
    Re: Winter/liner damage
    Yes take the cover off asap as it is already causing trouble. We have been seeing this quite often. To the point of almost saying no covers on above ground pools. I would think about making something like tie out lines to help keep the supports up. When I say tie out lines I am talking about how they use a stack and rope to help keep trees straight. Good luck and I hope the wall is not compromised. Let us know how it turns out.
    Jul 2013
    Long Island, NY
    578
    Yes agree with Kim, take the cover off.
    When there is heavy snow forecasted I either take my cover off the pool, or loosen the cover so much that it is "sitting" in the water. In your case, yes I would take the cover off the pool. I use a micromesh cover so the water just seeps through the cover so I don't have to worry about the weight of rain water pulling in the sides of the pool.
    Gallons: 5000 Gallons
    Pool: 15' Saltwater 5000
    Filter: Pentair 1 HP Optiflow Pump w/ Clean & Clear 75Sq Ft Cartridge Filter
    SWG: Intex CS8110
    Mar 2018
    West Deptford NJ
    2
    Thank you! We dropped the cover into the pool. I feel a lot better that pressure will not be on walls with the next storm rolling in tonight.
    I truly appreciate the advice from both responders.
    9 years old
    Jul 2013
    Long Island, NY
    578
    No problem, good luck.
    SWG: Intex CS8110
