Results 1 to 10 of 10
Thread: Pump Size for Sheer Descents
    Mar 2016
    Iowa
    21
    Hello all,
    This spring I plan on adding 6 feet worth of sheer descents to our pool. (2-24" and 2-12"). Using CMP's guidelines that calls for 72 GPM. Between the suction and return side I figure I'll have close to 200' of 2" pipe, 90' of it on the suction side. I would ideally like to have a pump just for these, but am wondering how big of pump to actually use. I've been told a 1-1/2 HP Whisperflo, but am questioning that, as it just barely goes below 30' of TDH on the performance curves. Am I better off going to a less HP pump for 72 GPM?
    Re: Pump Size for Sheer Descents
    As long as you size the pipe correctly, the distance is not an issue. I recommend 2.5" pipe.
    A WhisperFlo pump is not a good choice for a fountain.
    A water feature pump is designed to power a waterfall at low pressure but higher flow.
    Waterfall pumps run at half speed vs regular pumps (1725 rpm vs 3450 rpm).
    Alternatively, you can just use the return water from your main pump to feed the falls.
    Support the site
    Mar 2016
    Iowa
    21
    That was my initial line of thinking, to cut in a 3-way on the return side of my Intelliflo filter pump with an actuator to the Easy Touch. Is there any down side to doing this?
    Nov 2015
    Carrollton tx
    489
    I have (3) 3 foot sheers and a single VS pump on max rpm doesnt provide enough flow for a consistent look for all 3
    Like SWG - I would over size so you can turn down the wattage
    Edited to reflect 9 feet of sheers
    Doug - Purchased 1/2016, 1995 house with 16x31 ft, ~23000 gallon Gunite pool w 11x7 spa, 3 Pentair VS pumps, a boost pump for polaris 3900 and a BaduŽ Jet super-sport swim jet pump, 1.5 hp blower, a CL460 Cartridge filter. TF-100 test kit. Aquapure 1400 SWG, iAqualink - Lots to learn. New Aquabright, Jandy LEDs, CMP LED Sheers.
    The pump should provide enough flow. If not, then the water is probably not all going to the sheer descents.
    Using water from the main pump works well in many cases.
    The only downside that I can think of is maybe a loss of heat if the water is being heated before going to the sheers.
    Support the site
    Sep 2017
    Silicon Valley, CA
    464
    No expert here, but a data point. We have 3 feet (3x12") worth of sheers fed by a dedicated 1HP VS pump. We like the flow amount somewhere between 2000-2400rpm.
    We've got 2" pipe that downsizes to 1.5" by the time it tees off behind each of the sheers. Probably 20-25ft of pipe on the intake side, and 50-60 ft out to the sheers.
    18Kgal play pool+spillover spa, Tahoe Blue Quartzscape refurb June 2017, ~40'x15'
    1.5HP VS JeP, CCP420 cartridge filter, Sta-Rite 400HD, 1.0HP VS JeP for sheer descents
    Caretaker 5-port in-floor system, AP1400 SWCG, Aqualink: RS-8 Combo, iQ20, One-Touch
    K-1005, K-1515 FAS-DPD, K-1766, Taylor 9056 comparator, SpeedStir!
    Mar 2016
    Iowa
    21
    Quote Originally Posted by JamesW View Post
    This is where I thought using a 3 way diverter would work well. Should be able to completely isolate to the descents if needed.
    At 72 GPM for all the descents (1 GPM per inch), I didn't see why using the VS to power these would be an issue, but the gentleman that I had been talking to wholeheartedly disagreed. Above all, if it doesn't end up panning out, it would not be a big issue to have to re plumb in a new pump after the fact.
    The Intelliflo should work fine. The three way valve can send all water to the sheers for good effect.
    Many builders use WhisperFlo pumps but they're not a good choice.
    If you added a pump, where would you add the suction?
    Support the site
    Mar 2016
    Iowa
    21
    Was thinking in wall drains. Have a paver deck so pulling up and replacing wouldn't be too big of an issue.
    What at are your reasonings behind not recommending the whisperflo? Just curious.
    Exactly as you suspected, the head curve does not match the application.
    The WhisperFlo is designed to be able to generate a lot of pressure.
    However, a water feature typically is lower pressure and high flow.
    A WhisperFlo will waste a lot of power because it does not meet the application.
    Jandy, Pentair and Hayward all have waterfall pumps that are designed for the application.
    They provide the correct flow, they are quieter and they use less power.
    The operating point for the pump should be in the middle of the pump curve where the graph shows the best efficiency zone.
    Support the site
