Results 1 to 10 of 10
Thread: SWCG return jet plumbing
    The previous owners of my pool had been using Baquacil. Not knowing any better, I continued with that for a couple years before I made the switch to a salt system. Switching to salt was a great idea. Rushing to buy the salt system without completely figuring out how to connect it was not such a great idea...
    I got an Aquatrol system. There was an RJ option that was meant to be mounted vertically and connect directly to the return jet. The other option (HP) was meant to be mounted horizontally. The RJ option seemed more convenient and out of the way, so I went with that.
    When I went to install it I found out that my return jet (Aqualuminator) doesn't come straight out the side of my pool horizontally. Its output port is already angled downwards. So now my Salt Cell has a fitting on the top end with a 90deg elbow so that it can mount straight to the return jet. But my return jet port is already facing down, so it doesn't need this elbow fitting.
    There's a warning sticker on the elbow fitting that says it must be mounted vertically. The salt cell itself is a generic replacement part. So it can be used either vertically or horizontally depending on which system you have. I think that the HP option included a "flow switch." So I think that's what determines whether or not it can be mounted vertically or horizontally. I don't really understand the purpose of the flow switch though or why its not needed if mounted vertically.
    So if I want to keep this mounted vertically, I would need a replacement fitting that screws onto the Salt cell and has just a straight male port that could connect to a hose that attaches to the return port, right? Anyone know where to find that? I don't see it available as a replacement part from aquatrol.
    Here's a picture of the ridiculous way I have this cobbled together now:
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    35,035
    Re: SWCG return jet plumbing
    I have no idea but here is a bump to get it in front of more eyes.
    cfherrman's Avatar
    May 2017
    Hays, Kansas
    1,707
    Yeah I'm confused, can you get a picture that is zoomed out more?
    Casey
    Intex 24' x 52" closed for winter 2018, 2 Main Drains, 1 Skimmer, 1 Return, PVC
    1/2 HP Intex Pump 633T w/ Taeglus TA-40 175 lb 19.5" Sand Filter, Auqabot Extreme Robot
    TF-50 and Taylor 2006 Test Kits, Quality Well Water, Fleck 5800SXT Water Softener
    Quote Originally Posted by cfherrman View Post
    I could but its telling me I've exceeded my attachment quota. I'll try explaining better:
    Most return jets have their connection port oriented horizontally, coming straight out the side of the pool. Mine is an Aqualuminator and it has its port facing downwards:
    https://blog-media.thepoolfactory.co...t-1024x423.jpg
    In that picture, the bulb goes straight through to make some electrical connections and the hose connection port is facing downwards.
    My Salt cell came with a fitting that was meant to screw directly on to a horizontal facing return jet port. The cell is supposed to be vertical, so this fitting is a 90 deg elbow. So to get this connected in my case, I have to add another 90 deg connecter. In the picture above, this extra fitting is actually a 3 way valve with only 2 ports being used (because I had an extra one of those lying around and just wanted to get this connected and working).
    So I think what I want to do is replace the elbow fitting that came with the salt cell, with a straight one. Then I would still have that little short piece of hose connecting the cell to the return jet, but would no longer need the zig zag with the extra fitting.
    Jul 2012
    Tallahassee, FL
    35,035
    You can become a supporting member as seen here: CLICK HERE to Become a TroubleFreePool.com Supporter!! or use an outside photo hosting place that is NOT photobucket as they are charging $399 a year!!
    cfherrman's Avatar
    May 2017
    Hays, Kansas
    1,707
    Isn't the cell supposed to be mounted in the plumbing on the pad and in the pool?
    Postimage.com
    Casey
    Here's another angle
    That shows the return jet port facing downwards. The white elbow fitting at the bottom of the picture is attached to the salt cell. That white fitting was supposed to screw directly into a horizontal return jet port.
    cfherrman's Avatar
    May 2017
    Hays, Kansas
    1,707
    Seems fine if you can get the swg cell all the way vertical
    Casey
    I think this is the fitting I need to go straight up to the return port:
    http://waterwayparts.com/UNION-A SS.-2%22-X-1.5%22HOSE-400-9240/
    Had to add a space in that link to avoid a curse word...
    Jul 2012
    Tallahassee, FL
    35,035
    It does look like it would work!
