Results 1 to 12 of 12
Thread: Borate Users
    Aug 2015
    Plano, TX
    217
    Borate Users
    Is everyone still getting their boric acid from dudadiesel.com? Or does everyone just buy the borax itself from the store?
    Curtis- 20k gallon IG gunnite/plaster with hot tub/waterfall and "grotto"
    All Jandy equipment: 60sqft DE filter - 399k btu natural gas heater - Stealth pumps - iAquaLink RS8.
    Polaris 9400 on patrol.
    TF-100 in da house/TFP method in effect: FC=4-6, pH=7.5, TA=80, CH=250, CYA=50, Borate=50, CSI=-0.21
    AftonJeeper's Avatar
    May 2017
    Twin Cities, MN
    1,147
    Re: Borate Users
    I ordered mine from bulk apothecary
    20'x48' 40,000 gal. Vinyl, Pentair Intelliflo 2 VST, Sta-Rite PLM300 System 2 Cartridge Filter, and a Pentair Mastertemp 250 heater all controlled by Pentair Easy Touch with Screen Logic. Dolphin Premier pool attendant.
    I've got iron stained well water. TF-100 and Speed Stir, Lamotte 3017-G for Borates
    JoyfulNoise's Avatar
    May 2015
    14,226
    Re: Borate Users
    Boric acid is the better method. The cost is about the same but it is MUCH easier. Boric acid is a weak acid so it changes pH very little while borax is a strong base and raises pH strongly. Accidental scaling of calcium is much more likely with borax.
    Matt
    Aug 2015
    Plano, TX
    217
    Re: Borate Users
    It does look like Bulk Apothecary is a little cheaper than Duda Diesel, which is where I normally buy my boric acid.
    Matt, my question was more about where forum users are buying their boric acid these days (the ones that use it).
    The reason I ask is because I found somewhere that I can buy A LOT of boric acid from for REALLY CHEAP. Like 6 pallets of it. Way more than I can use in a lifetime but I was thinking I could save some forum members some money by selling it on here. Not in an official capacity, I mean I don't have a business selling pool chemicals, more like a friendly hook-up for us forum members. The only problem is that it's in powder form instead of granular form. So I'm trying to decide if it would be beneficial at all to buy the stuff or not if no one is going to want it. It seems like most people on here use the granular form and I don't know if they would be willing to switch to save some cash.
    May 2015
    14,226
    Re: Borate Users
    No to powdered form. It's way too fine and even the slightest breeze (like a cat breathing heavily) will cause it to go all over the place. It will also float on the water rather than sink and dissolve.
    You want granular boric acid...period.
    Matt
    Aug 2015
    Plano, TX
    217
    Re: Borate Users
    What if you mixed it with water inside the house and then added the slurry to the pool? That's what I do with my baking soda when making TA adjustments.
    May 2015
    14,226
    Re: Borate Users
    Quote Originally Posted by Ale_Brewer View Post
    Seems like a lot of neat work to me. Your average sized pool needs 25-35lbs of boric acid to reach 50ppm B concentration. At a room temperature solubility of 57 g/L (~ 0.5 lb/gal), that’s going to be a lot of trips back and forth.
    Matt
    Aug 2015
    Plano, TX
    217
    Re: Borate Users
    But what if you could get it for half price? I imagine that most of us here have already done the initial dose and are just adding small amounts for maintenance.
    May 2015
    14,226
    Re: Borate Users
    Meh.
    Difference is $35 versus about $80 delivered. Not really a big deal to me. Being lazy and just tossing a few pounds of granules into the pool with a quick brush is a big deal to me. Honestly, if I were forced to use the borax/MA method where you kinda have to premix the borax in a bucket and add it slowly to the pool, I wouldn’t add borates at all.
    Matt
    Aug 2015
    Plano, TX
    217
    Re: Borate Users
    I just meant mixing the powdered boric acid with water so the wind doesn't take it. I will never do the borax/ma method again.
    HOO's Avatar
    Jun 2015
    Freeland MI
    9
    Re: Borate Users
    I know what you are going to say, but I've been using Pro Team Supreme Plus for a couple of years. If you want "easy" and don't mind the cost, this is the way to go.
    10,500 gallon in-ground vinyl pool with Hayward Max-Flo XL 1HP pump, Hayward DE3620 DE filter, Hayward 150K BTU heater, CircuPool Si 30 SWG and Polaris 9550 robotic cleaner named Ezra
    May 2015
    14,226
    Re: Borate Users
    Whatever floats your boat. The ProTeam stuff is just a mixture of borax/boric acid to produce a pH neutral effect. Boric acid does lower pH but not typically by more than 0.2-0.3 units for a 50ppm B load. Since most people have issues with rising pH, the boric acid method works well. That said, you do have to buy large quantities of boric acid (25lbs buckets) as opposed nicely packaged bottles.
    It’s kind of like liquid CYA versus granular CYA - pros & cons for both but you eventually get the same effect.
    Matt
