Thread: getting ready for pool openin
    rajung's Avatar
    Mar 2015
    Iowa
    284
    Getting close here, ok, 6 weeks away but working on my plan.
    Currently I have my heater set on one of those plastic grey equipment pads, worked fine for 3 years but now starting to lean a little which causes all the lines to the filter and pump not fit the best, but did not leak.
    Going to have one large pad poured for filter, pump and heater.
    But my question is?
    Right now all is exposed to the elements without shade.
    Sun exposure about 90% of the time.
    The clear thread on strainer basket cover for my pump ends up with a split along the cut threads almost every other year which starts to leak, causing me to keep 3 lids on hand, many times on back order so I may not be the only one.
    Regardless of how tight or loose I keep them screwed on.
    I don't tighten very much because they will tighten after awhile on their own.
    Has anybody else had a problem with these lids? and wondering if I should come up with some sort of roof or cover over all the equipment in case it is UV causing the problem.
    Doughboy AG 16' x 32' oval, 13,700 gal.
    AquaView by Doughboy 150lb sand filter model 0-1709-20
    PowerLine pump by Doughboy model 0-3047-200, 1.5hp-single speed-20amp
    Gulfstream electric heater-HE125-R-A
    Taylor K-2006 test kit
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    10,191
    Re: getting ready for pool openin
    It's almost certainly UV and nobody here is gonna argue building a cover over your equipment pad. Just make sure that pump gets plenty of air circulation.
