Results 1 to 7 of 7
Thread: VS and solar panels. Controller advice needed
    Mar 2018
    Yorba Linda, ca
    9
    I am adding solar panels to my pool and will also be changing out the pump. I want to go variable speed. The solar system came with a Hayward Auqasolar TC controller. I donít see an easy way to make it work with the VS pump. I am thinking that the best bet is to sell this off and get the Pentair pump and their controller (it looks like these are designed to connect to each other).
    Does anyone have this system, does it operate as simply as the instructions show?
    Has anyone hooked up the Auqasolar with a Pentair VS pump?
    thanks for any help
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    10,153
    Re: VS and solar panels. Controller advice needed
    Ron,
    Welcome to TFP... a great place to find the answers to all your pool equipment questions...
    I tried to download the manual for your controller and for some reason it would not load???
    Pentair makes several different VS pumps.... some can be controlled by external relay inputs and others only by propriety serial signals...
    If your plan was the buy one of the IntelliFlo version pumps, then it is unlikely that anything but a Pentair Solar controller will work with it..
    Tells us more about your pool, it might makes sense to buy an automation system that includes a solar controller... Depending on what you buy, you could then control your pool from your PC, Tablet, or Phone..
    Thanks for posting,
    17K Gal, IG, 20' x 25' Almost Rectangular Pool, Pebble finish, three rockport water falls. Pentair Equipment: EasyTouch 4 (now 8), IC40 SWG, 3 HP VS Pump, CCP520 Cartridge Filter.
    Mar 2018
    Yorba Linda, ca
    9
    the Controller information is here
    https://shop.solardirect.com/pdf/poo...all-manual.pdf
    I am not sure the pentair allow the for control through the relays?
    It looks like I might have to buy more parts to make them talk to each other.
    I am installing the solar panels in with about a 60 foot run.
    No other heater on the pool, I want the pump to run at low speeds and then kick up for the solar panels
    I will look at the automated systems from pentair to see if they use that data cable
    thank you for any advice
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    The superflo vs pump has external relay control. I know because that's how my solar panels control my pump. I did my controls myself. You will need the data input cable for the pump to do it.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    Jul 2014
    Bedford, TX
    10,153
    Ron,
    The unit you have has the ability to turn on/off external relays.. So with the addition of an external relay, and some wire, it could be made to control the Pentair VS SuperFlo pump.
    It will not control the VS IntelliFlo pump.
    Mar 2018
    Yorba Linda, ca
    9
    Thank you
    I will look into it further
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,723
    Welcome to TFP Ron
    When you get a chance please add you pools info to your signature as outlined here. Pool School - Getting Started
    You can always update it with any changes you make.
    32K IG Vinyl, Lazy L, Hayward SuperPump 1.5hp, S240 Sand Filter W/DE
    Solar Blanket, Well Water, Borax Added. <32į
