Thread: Spa heater recommendation
    Nov 2017
    Space Coast, FL
    86
    Currently we have a propane heater for the spa. It has been leaking, so I by-passed it when I replaced the pump.
    A friend has an insta-hot type of heater (don't remember the make) and likes it.
    I liked the gas heater as the spa got up to temp fast.
    Any suggestions?
    DAB
    25K Gallon In-ground Pool with Elevated Spa - Gunite, Hayward 3400VSP, 150 Pentair Cartridge Filter, Hayward In-Line Chlorinator, Zodiac MX8 Pool cleaner - TF 100 test Kit w/ SpeedStir - Space Coast of Florida
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    35,035
    Re: Spa heater recommendation
    The brand that gets the most nods is Raypack. Gas does get the water hot fast! Not sure how much water one of the insta-hot type of heaters can heat at one time. You need to look at your electric costs compared to gas costs. In some areas that alone will make up your mind with kind of heater to use.
    Kim
