Results 1 to 13 of 13
Thread: jandy valve control
    Mar 2018
    Chandler, AZ
    13
    jandy valve control
    Picture shows the plumbing out of my filter. ignore the two small 3/4" for aerators, not finished yet.
    Pipe 1 i believe is the return.
    Pipe 2 and 3 are for the bubbler and water sheer.
    Given how the jandy valve is installed between pipe 2 and pipe 3, my understanding is:
    a. i can turn off both pipe 2 and 3
    b. i can turn on both pipe 2 and 3 (as shown in picture, current jandy valve position)
    c. i can turn on pipe 2 and turn off pipe 3.
    But given the current installation, can I have pipe 2 off and pipe 3 on ? It seems like it won't do this? But i think i would want that capability, for full independent control of bubbler and water sheer.
    Thoughts?
    My Pool: Gunite; 12,000 Gal; mini-pebble aqua white, Pentair VSF pump 011056; Pentair CCP520 Ctg filter; Pentair intelliBrite 5G color 601001 with controller 600054
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,471
    Re: jandy valve control
    Quote Originally Posted by eyo_007 View Post
    Thoughts?
    Hi welcome to TFP. Turn the handle on pipe 2 180 degrees, or the OFF writing facing down
    6,000 gal, IG free form,Beach Series Antigua by Marbletite Pebble finish,Sheer Descent, IG Fountain, Dolphin / Mermaid Statues,Dura- Glas 1.5hp pump,Hayward Pro-grid DE4820, Aqua Rite SWG with T-Cell 15,Heat Siphon Heat Pump DX 5.0 109,000 btu, Pool Cage, 1800sq ft Tremron Estate Pavers,Aquatherm Ecosun Solar Panels 192 sq ft with GL-235 Controller,Pentair IntelliBrite, Apollo Magnetic Stirrer Our New Poolbuild, Jacksonville, FL yr 2009 Solar install Outdoor kitchen upgrade
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,849
    eyo,
    Well, my initial "thought" is your pool builder is an idiot..
    It appears that your valves have stops built in to the valve body that prevent the number two valve from being turned to point down. You can cut the stops off which will allow the valve to turn.
    I think a better set up would have been to install a two way valve on both pipes 2 and 3, instead of the three way.. this would have allowed independent operation of both the bubbler and the waterfall and also allowed you to control the amount of water flowing through each water feature.
    Thanks for posting,
    Mar 2018
    Chandler, AZ
    13
    yes, that's exactly the issue i saw. That the stop on the valve body is preventing the handle to be turned 180 degree from the picture. Thanks both your help in confirming my understanding.
    Any others ever have to cut the stop on their jandy valve before ?
    Jul 2014
    Bedford, TX
    9,849
    eyo,
    If this is a new pool, you should tell the pool builder to come out and do it right...
    Feb 2015
    Chandler AZ
    1,077
    For the valve above pipe #2 - with the pump off, remove the 8 screws and rotate the lid 90 degrees clockwise. Reinstall the 8 screws. This should give you the ability to control 2 and 3 individually.
    You may also wish to consider painting all the white PVC to protect it from out harsh AZ sun.
    Gene
    ​12,300 gal IG play pool - Pebbletec - built 10/1999 || Hayward S360SX 36" sand filter || Hayward Ecostar SP3400 VSP || A&A In-Floor cleaning system || Quik Water Leveler || Quik Dek-clor (limited use)
    TF-100 testkit / Speedstir - A good test kit is not an expense, it's an investment
    Mar 2018
    Chandler, AZ
    13
    Thanks for the tip on painting the PVC, i have added that to the to-do list. Plan on putting up a sail shade above the equipment area as well.
    Jul 2014
    Bedford, TX
    9,849
    Quote Originally Posted by proavia View Post
    Gene,
    Sure.. do it the easy way!!!
    Good catch... I did not even think of doing that... I have a different style of valves with different stops..
    Mar 2018
    Chandler, AZ
    13
    Thanks all for all the ideas of how to correct this!
    Feb 2015
    Chandler AZ
    1,077
    Quote Originally Posted by Jimrahbe View Post
    Gene,
    Sometimes I just get lucky.
    Always best not to cut off the tab. If you cut off the tab, there is always the chance of deadheading the valve - preventing any water flow - and causing damage to the plumbing.
    Gene
    Jul 2014
    Bedford, TX
    9,849
    Gene,
    In general you are absolutely correct, but I did take that into account based upon the valve's location. In this case it can't be worse than what the valve can already do... As is, it can already shut off all the flow to 2 and 3...
    Thanks again for you help on this one,
    Are you sure that it's a Jandy brand valve?
    It looks like a different brand.
    I would avoid pulling screws and taking the valve apart.
    I would modify the stops if that's easy to do.
    Support the site
    Feb 2015
    Chandler AZ
    1,077
    I'm guessing they might be Waterway Tru-Seal valves - based on the handle design.
    Waterway Truseal Valve Parts - INYOPools.com
    In looking at the parts diagram at the above link, it appears to work similar to the Jandy brand valves. Difficult to tell if the lid is marked with any wording to indicate the inlet side (like the Jandy brand is).
    On the Jandy brand valves: For return side use, 'inlet' is usually on the side water is coming from (pump/filter side). For suction side use, 'inlet' is usually on the side water is going to (pump side). Based on plumbing layout, any of the 3 ports can be used as the 'inlet' by adjusting the lid accordingly.
    Gene
