Results 1 to 9 of 9
Thread: Heater Questions
    Mar 2018
    new jersey
    8
    Heater Questions
    Here I am again )
    As I mentioned in my intro, I'm in the market for a new heater.
    Because of my gas piping situation (aprox 90' run of 1" black pipe) I started many years ago using the Hayward 100,000 BTU Heater. It's always done a good job for me but I will be on my 3rd or 4th heater now. This is over maybe 20 - 25 years, or when they first came out.
    I'm a real die hard with the pool so I open it early...end of April or so and I've closed it as late as Halloween )
    When I start the pool up the heater is turned on and basically stays on until I close the pool. My wife & I like it at 86 best. Sometimes in the summer I have to dial it back some because it gets too hot.
    Over the years, I've replaced heat exchangers, gas valves, control boards, fans....the whole nine yards. I stopped going thru heat exchangers when I stopped putting tabs in the skimmer and started keeping my PH balanced.
    As you might know the heat exchanger on the hayward is finned copper tubing. I see the Raypak is an additional 30,000 BTU's and might have a cupro nickle exchanger.
    Given the 1" run of my gas line..... and the decent experience I've had with Hayward (I think it's decent but then again... I'm in a vaccuum here) My question is... Should I stay with the Hayward or switch it up to a Raypak or Pentair?
    I haven't done any real research yet so I am taking the lazy route and asking any of you that have experienced the Hayward and have stuck with it or moved on.
    I'm open to all idea's and recomendations but will not upgrade the gas line!
    Thanks for listening..... I mean reading )
    Cooper
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,542
    Re: Heater Questions
    Definitely the water chemistry makes a difference, but sounds like you're onto it, and in any event I'll leave that and brands for others to comment.
    In my past work life though, we often had to upgrade gas equipment. Very often, the installer was able to raise the pressure on a branch, or have the gas company do it at the regulator at the meter, and then adjust all the gas appliances accordingly. I have no idea if it's an option in residential, but it might be worth asking a gasfitter.
    12k IG salt; glass beads in plaster; K-2006C, K-1766, K-1106 and CCL test kits; Pentair Eco800 1.2HP VS; Zodiac SWCG 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; Other family pools 10K SWCG and 15K on liquid; PoolMath app subscriber; | Tips for New Members to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    Mar 2018
    new jersey
    8
    Quote Originally Posted by needsajet View Post
    Thanks for the reply!
    I did adjust the regulator to slightly raise the pressure at the heater when I installed the first one. My buddy has an inground with a 350,000 BTU heater and he has an 1 1/4 or 1 1/2 line running out to the pool and had to get a higher volume meter. The heater really does a fine job heating the pool. I'm just thinking the nickle exchanger may give me more life.
    Cooper
    Jan 2012
    'burbs of Augusta, Georgia
    8,865
    Raypacks get real positive feedback here on the forum.
    Maddie
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    Mar 2018
    new jersey
    8
    Thank you Maddie!
    RoxxW's Avatar
    Dec 2016
    Poquoson, VA
    120
    Quote Originally Posted by YippeeSkippy View Post
    Maddie
    I'm with Maddie. Raypak heaters are more often positive feedback on this forum and this is the company I am thinking of going with.
    Yardmore 18'x33'x54" Saltwater LX Oval Pool Semi Inground 18K Gal, Hayward XStream 150 Cartridge Filter System 1.5-HP Power-Flo Pump, Hayward Aqua Trol RJ Salt Chlorine Generator System, Hayward Thru-Wall Skimmer & Return Fitting, SmartPool PT7i Inground Climbing Robotic Pool Cleaner, TF-100 Test Kit XL Option, https://drive.google.com/drive/folde...kk?usp=sharing
    Jul 2012
    Chicago, IL
    387
    I'll drop in my vote for raypak, it gets a lot of love on this forum. I've had mine for 3 seasons (since 2015) and love it.
    Dedicated TFPer since 2012 with recommended test kit
    AGP, 30 foot, 21,000 gallons with these homemade islands
    Hayward 150 sq foot cartridge filter, 1HP Waterway pump
    Raypak 400K BTU NG Heater! (Model 406a - installed 2015)
    Pool installed in 2006? (just a guess, pool came with house I purchased in June 2012)
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,627
    Yep Raypak for the win.
    Very happy with mine, installed a year ago.
    on the nickle exchanger, the consensus is that upgrade is considered wasted money fyi.
    Dolphin E10 Cleaning Robot.
    Mar 2018
    new jersey
    8
    Thanks for all the Raypak feedback guys!
