Thread: PH target
    Sep 2017
    Tucson
    40
    PH target
    Every weekend I do a full TF100 test on my pool water. Then I plug the numbers into PoolMath. I then adjust the PH number until a get a CSI of 0. I use the adjusted PH number as my target PH for that week. Is this a good way to do it?
    12500 total gallons IG pebbletec, 12000 pool 500 spa with spillway and waterfall, (Pac-Fab) Pentair sand filter
    (Pac-Fab) Pentair Challenger 2hp
    The Pool Cleaner side suction
    Testing: TF-100, Taylor K-1515-A, ColorQ 7 Pro, AquaCheck7 strips
    Jun 2011
    Miami, FL
    125
    PH target
    I think as long as you’’re in range, that’s what counts. I would set a set of parameters within the ranges that are as close to 0 as possible, and maintain those numbers weekly.
    15X30 FreeForm IG with Spa, CLI CrystalStones Smooth Pebble Finish, CompuPool cpsc24 SWG, Hayward 175 sq. ft. CF, Hayward 1.5hp Single Speed Superpump, Jandy iq20 automation, Pentair Intellibrite LED 5G pool and Spa lights, Dolphin Active 30i, Taylor K-2006
    Jun 2014
    17,795
    Re: PH target
    It's good that you are so vigilant with your pH as that does indeed have the most immediate effect on your CSI level as you may have already noticed in Poolmath. But always be mindful of the counterparts to the CSI equation (TA and CH) and those have their own importance as well. And it's okay if you're not exactly at "0" CSI, that's why there's a window to shoot for because some folks do have to keep the TA or CH in a more ideal range for other reasons (i.e. heaters, SWG, etc). Most importantly, though, as sd122 noted, keeping all items within the TFP Recommended Levels should ensure your CSI is in a good place at all times. Having that TF-100 is a key product in achieving those results.
    By the way, if you haven't heard it already ... THANK YOU for being a TFP supporter.
    Re: PH target
    What are your readings?
    Support the site
