Results 1 to 16 of 16
Thread: Purchasing a new filter
    StraBary's Avatar
    May 2017
    Avon park, fl
    16
    I am purchasing a new filter for my 18,800 gallon pool that is not screened in. I am leaning towards a canister filter but I am not sure what size I need. Also which brand is the most reliable? Thank you for your help!
    Heather
    18,800 gallons; sand filter; plaster
    cfherrman's Avatar
    May 2017
    Hays, Kansas
    1,702
    Re: Purchasing a new filter
    What size of sand filter do you have currently and how long do you go before s backwash?
    Casey
    Intex 24' x 52" closed for winter 2018, 2 Main Drains, 1 Skimmer, 1 Return, PVC
    1/2 HP Intex Pump 633T w/ Taeglus TA-40 175 lb 19.5" Sand Filter, Auqabot Extreme Robot
    TF-50 and Taylor 2006 Test Kits, Quality Well Water, Fleck 5800SXT Water Softener
    StraBary's Avatar
    May 2017
    Avon park, fl
    16
    It is an old Tagulus 60D, I'm not sure about the diameter but it is approximately 26". We have to backwash often bc we're fairly certain the sand hasn't been changed in over 10 years. By often I mean once or twice a day.
    Heather
    Jun 2014
    17,795
    If you're going to change over from sand to cartridge, the major brands like Hayward and Pentair are all very popular, reliable, and have good warranty departments if you have a problem. What you might want to look at is your current plumbing size to see if the PVC is a good fit or if there will be any changes required for the new & old stuff to mate.
    As for the size, while there are many that say will work, and probably will, we often recommend going with a much larger filter simply to reduce the amount of times required to rinse the cartridges per year. For example, in the Hayward line you'd probably want to look at a multi-cartridge filter, something along the 325 or 425 series sizes. Pentair offers comparable 320 & 420 series models. Each company even has a larger model. Like I said though, smaller ones will work, but require more frequent cleaning. When my pool was installed, it came with a single cartridge Hayward filter. It works fine, but I have to rinse it off about every 3-4 weeks during the swim season. I'll probably upgrade once this one is done.
    Hope that helps.
    cfherrman's Avatar
    May 2017
    Hays, Kansas
    1,702
    If your able to pop the top of your sand filter, deep clean it with a garden hose, and top it u with #20 sand it will save you a big nch of money.
    Casey
    StraBary's Avatar
    May 2017
    Avon park, fl
    16
    Thank you, I am considering the Haywood 240 or 325. I know the 240 is technically big enough but I was thinking I should get the 325 to be more efficient.
    Quote Originally Posted by cfherrman View Post
    Thank you and I did consider this, I even considered putting zero bright in the sand filter but it had a small leak. We popped the top off and found some of the gasket had worn down in places and when we put it back on, it leaked even more.
    Heather
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,833
    Heather,
    If you have to backwash almost everyday something is wrong.. If you have been fighting algae and have been using Floc or Clarifier, it can cause your filter to plug up..
    Algae is a chemical issue, and not a filter issue, so if you have been fighting algae, replacing your filter will not solve the source of the problem.
    What color is your water?
    StraBary's Avatar
    May 2017
    Avon park, fl
    16
    Quote Originally Posted by Jimrahbe View Post
    Heather,
    My water now is blueish but it turns green quickly if we don't add chlorine every couple of days. When bought the house a year ago the yard and the pool were not maintained. The sand is mostly gone and needs to be replaced. However, it is an old 2006 filter that leaks. That's the main reason for the change. What should my husband do to clean the pvc pipes before he installs the new filter to help with the algae problem?
    Heather
    Jul 2014
    Bedford, TX
    9,833
    Heather,
    There is nothing wrong with installing a new filter, what I was pointing out is that if you have algae, the new filter will stop up just as fast as your old one.
    When you have a pool that "turns green" quickly that means you have algae.. When it turns "blueish" that means that you have been able to kill the algae you can see, but there is still plenty of algae you can't see... Since you are not killing it all, then it will just keep coming back..
    The way to eliminate algae is to perform what we call a SLAM... See this link.. SLAM Notice that the SLAM process is not a one-and-done thing.. You have to Maintain the "Shock FC level" until all the algae is dead and you pass the three SLAM requirements.
    Not sure how you are currently testing your pool water, but to perform a SLAM you need to be able to measure your own pool water and you need an accurate test kit that can measure the FC (Chlorine) level up to 30 or 40 ppm, which simple kits just cannot do..
    I suggest either the TF-100 test kit, or the Taylor K-2006C test kit.. And yes, the "C" is important as it has more reagents...
    If you are not familiar with the TFP process of maintaining a pool, I would suggest you read through our Pool School.... See this... Pool School - Pool School
    Thanks for posting and good luck with your filter upgrade.
    cfherrman's Avatar
    May 2017
    Hays, Kansas
    1,702
    Dead algae gets caught in the filter, seems like you are continuingly fighting algae and making lots of dead algae.
    Might be a good idea depending on cost of sand and a gasket, and anything else your filter needs (if it's not too far gone) to take total control of the pool as Jim is talking about, fix the pool chemistry, and then decide on the filter change after that. (If current filter can be limped along without much money)
    Slamming the pool should take of the pipes, if not awesome (chemical) can clean out biofilm in the pipes.
    Casey
    StraBary's Avatar
    May 2017
    Avon park, fl
    16
    Hi Jim,
    Even after the slam process, I have a hard time keeping my pool blue. I have maintained the 16ppm for several days until it is blue. It always goes back to green if I only put in 2.5 gallons once a week and have 2 tablets floating in the pool. I try to maintain the chlorine at 7ppm and it still goes green. I have the TF-100 test kit and I have read pool school and thank you for it because I am so much more knowledgeable than I was a year ago!
    I am hoping that a new filter will require less chlorine to keep it blue. I think the problem is the leaking and replacing water keeps unbalancing the pool. Also the old or missing sand is a problem. Once I install the new filter should I slam it again? Or just maintain the right levels?
    Thank you,
    Heather
    Heather
    What is your CYA level and does the fc ever go below 7.5% of the CYA?
    Support the site
    StraBary's Avatar
    May 2017
    Avon park, fl
    16
    Right now my cya is zero bc I am not adding any until I get the new filter. The old filter leaks out and it is hard to keep cya levels up.
    Heather
    What's the lowest the fc has been in the last two weeks?
    Support the site
    cfherrman's Avatar
    May 2017
    Hays, Kansas
    1,702
    Most likely you are not completing the slam with the oclt or the cc test, there probably some algae hidden behind a light or step, maybe your right the cya is being washed out.
    Do what you need to do to slam the pool
    Casey
    Jul 2014
    Bedford, TX
    9,833
    Heather,
    It will not hurt to replace the filter and then get rid of your algae... You will just have to be prepared to clean the cartridge quite often...
    It is your pool and you can do it however you want.. Just keep in mind that a new filter will not fix the problem...
    Thanks for posting and glad to see you are using a good test kit.
    Once you get the new filter installed, if you need any help getting the SLAM done, just give us a ring...
