Thread: IntelliFlo 3,450rpm during priming by default. Does it need to be that high?
    May 2017
    Lexington, SC
    144
    Is there a reason it needs to spin up to the max RPM to prime or can/should I configure it to be less during priming?
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,906
    Re: IntelliFlo 3,450rpm during priming by default. Does it need to be that high?
    raw,
    No it does not...Look at the IntelliFlo manual and it will explain how to adjust max speed... You can also set several priming factors such as Primed Sensitivity.. Default is 1% which means the pump needs to see a massive amount of water before it thinks it is primed.. I'd increase this to 50% or up.. The pump should then come out of the priming mode much quicker..
    Thanks for posting,
    May 2017
    Lexington, SC
    144
    Thank you Jim! I am definitely going to do this. If I change the Max RPM, is that just the max during priming or is that changing the Max RPM for any operation? Sometimes I like to be able to run it at 3450 if I need to briefly for vacuuming or something else. Wasn't sure if this was a global kind of setting or just as it relates to priming.
    Jul 2014
    Bedford, TX
    9,906
    raw,
    It will change the max for everything... That said, I can't see needing 3450 rpm for anything..
    Play with the Priming modes, there appear to be several options.
    And.. you really need to complete your signature so that everyone here knows what type of pool and equipment you have.. It makes answering questions much easier..
    May 2017
    Lexington, SC
    144
    Thanks Jim! I had totally forgotten about my signature but we'll get on that. Thanks for the reminder!
