Results 1 to 10 of 10
Thread: Crystal Pure Salt System: Heavy Duty - Thoughts?
    Aug 2015
    Hollywood, FL
    135
    Planning to do a Salt System. Local Pool store has sales planned for April on Hayward, was also looking at the much more cost effective Crystal Pure Sale System from Inyo Pools (they were great when I bought a replacement motor).
    I have an 11,000 gallon pool. If I get a Hayward, they make a 15K or 40K rated one. The 15K would mean running high capacity, 40K would be just right around 30%.
    Inyo Offers a 60K rated one as well. That one would run around 15% (give or take) and should last a LONG time. They now sell a "Heavy Duty" -- shipping March 25th -- supposed to offer 10,000 hrs of Salt (instead of 7,000).
    On the one hand, price wise, the 60K Heavy Duty at 20% whould last 17 years... which seems like overkill given a 3 year warranty. Even the 40K regular should last 7 years.
    Am I overthinking this? Does the Heavy Duty make any sense? Should I fork over the money for the name brand?
    Thanks everyone! Been saving up a few months, was about to pull the trigger when local store mentioned April sales (I was picking up Chlorine/Acid), and then saw the Heavy Duty option on Inyo.
    Alex
    Pool, 11000 Gallon Gunite Pool, shallow ( < 5' deep ) including spa. Hayward 1750 Cartridge Filter. Pump is a single speed 2 HP Hayward Northstar. Polaris Caretaker 5 Zone Floor System. Pool ~ 8 years old. TF-100 Test Kit.
    Jan 2012
    'burbs of Augusta, Georgia
    8,861
    Re: Crystal Pure Salt System: Heavy Duty - Thoughts?
    I'd just go for the 40k one unless the price for the higher ones is barely more. That's my opinion, not working on any facts.
    Maddie
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    cfherrman's Avatar
    May 2017
    Hays, Kansas
    1,707
    How good are you at taking care if your pool? Do you slack a bit?
    If your super up on pool chemistry run the numbers for price per pound of clorine over the life of the cell and get the cheapest one.
    Hate math or better than average pool care taker, 40
    Casey
    Intex 24' x 52" closed for winter 2018, 2 Main Drains, 1 Skimmer, 1 Return, PVC
    1/2 HP Intex Pump 633T w/ Taeglus TA-40 175 lb 19.5" Sand Filter, Auqabot Extreme Robot
    TF-50 and Taylor 2006 Test Kits, Quality Well Water, Fleck 5800SXT Water Softener
    Aug 2015
    Hollywood, FL
    135
    Um, by normal standards? I'm very good at taking care of my pool
    By TFP standards? So abusive...
    Jan 2012
    8,861
    Quote Originally Posted by Alex_H View Post
    LOL...sorry..that just made me laugh.
    Maddie
    Alwayswantedapool's Avatar
    Jun 2015
    York SC
    202
    I just bought the 40 heavy duty, it was $100 more for the increased warranty and life so made sense to me
    Mark, Pool: 30,000 gallon, IG Vinyl, Pentair Superflo Variable Speed 1.5 HP pump, Hayward S220T Sand Filter, Taylor k-2006 Test kit with speedstir. Dolphin Nautilus Plus.
    Hot Tub: Hot Spring Grandee 450 Gallons, Ace System (Salt water Chlorine Generator) Dichlor / Bleach method. Taylor K1766 Salt Test.
    Aug 2015
    Hollywood, FL
    135
    Quote Originally Posted by Alwayswantedapool View Post
    It's like an extra $100 or $200 for the 60, so 50% more life for not much more was my thought... I figured that the Heavy Duty 60 removed "parts" from the equation entirely. The control system will die before the salt cell.
    Jul 2015
    Southlake, TX
    11
    I just ordered the PL7707 40k Heavy Duty from Inyo, waiting to receive it. When I did the math, the extra $ over the standard 40k was not favorable. But I save the hassle of swapping the cell out down the line for a year or so. To me thatís worth it.
    Does anyone know if the Crystal Pure 40k or 40k Heavy Duty can be controlled by automation? A friend just got his and canít seem to locate where the four wires need to go.
    Thanks!
    32,000 gal. gunite with spa, Hayward Aquarite 40,000, Pentair DE filter 60 sqft.
    Jul 2015
    Southlake, TX
    11
    Quote Originally Posted by TXtransplant View Post
    Thanks!
    OK, per Inyo support the Pureline Crystal Pure units are not able to be controlled by automation, even though they are nearly identical to the Hayward salt cells. This is a drawback if you want to set the Chlorinator not to run in Spa mode, or to remotely monitor or adjust the settings.
    Aug 2015
    Hollywood, FL
    135
    Interesting. I keep toying with automation and not pulling the trigger. I'd need to replumb at the pump pad, not majorly, but when I look to do it, it's like $4k for the automation system and the better part of a day messing with PVC. I think I'm going to pull the trigger on a more basic Crystal Pure one, and if I want to automate later, automate later.
