Results 1 to 11 of 11
Thread: Outdoor refrigerator worth the price?
    I'm in the beginning phase of building an outdoor kitchen for my pool down here in Florida. Can anyone comment on whether or not it's worth the extra cost to purchase an "outdoor rated" refrigerator? Will a normal mini fridge be able to keep cool down here with the humidity?
    Jan 2012
    'burbs of Augusta, Georgia
    8,852
    Re: Outdoor refrigerator worth the price?
    I don't believe the traditional indoor "mini" or "dormroom" type fridge has the insulation for outdoor use. Or protection possibly from the elements of rain and such.
    Maddie
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    Aug 2017
    Toronto, Canada
    80
    Im also building an outdoor kitchen, I ended up buying an outdoor rated Danby fridge from Costco (also found at Walmart, HD, Lowes) for a few hundred $.
    Since one normally builds an outdoor kitchen around item dimensions its best that you figure out what fridge, etc you are using first.
    Pool: 10'x20'x4' - 6,000gal - Vinyl Liner IG - Hayward Maxflow VSP SP23520VSP - Hayward H250ED2 250k - Hayward Prologic 8 - Hayward T-Cell-15 SWG - Hayward 24" LED waterfalls (x3) - Hayward GVA-24 3-way - Hayward Aqua Connect - Hayward Wireless Table top Remote - Pentair Posi-Clear RP Cartridge filter 200sq - AquaLamp 12v LED multicolor pool lights (x2) - Inline Zinc anode rod
    ctrav's Avatar
    Apr 2017
    Northlake TX
    2,347
    With the heat here in Texas it seems my neighbors replace them boy every 3 years. For that reason I do not own one! I'm good with having a small cooler on the patio or by the pool...
    Cliff, IG, 22K gal, Pentair WF 2HP 2 Speed Pump, Pentair FNS Plus 60 DE Filter, Hayward PL Plus Pool Management, SWG T Cell-15, 2 LED Hayward Color Logic 4.0 Lights, Water Features, Diamond Brite Black Onyx pool finish, TF-100 Test Kit, PoolMath App, Dolphin S200 Robot (Phin). Northlake, TX New Pool Build
    I support TFP Forums ♥ Has the info saved you $? You can support too!
    May 2017
    Southern NJ
    103
    There are several levels of outdoor refrigerators, and what you'll need depends on your intended use/placement. The main features of outdoor refrigerators are bigger compressor/more insulation, enclosed back (water and critter resistance) and front vent. Most important is closed back, which can be found on the cheapest outdoor fridges. Front vent is needed only if you're installing in a tight-fitting cabinet. Larger compressor/more insulation = higher price.
    I have a low-range outdoor fridge, cost about $250. Closed back, rear vent, probably only slightly better insulation/compressor than a dorm fridge. Installed in a vented cabinet under a pavilion. Keeps beer in the high 30s on 90+ degree days, which is good enough for me. A $1k fridge would probably keep it at a crisp 32, but not worth the extra expense for me. Had a basic $75 dorm fridge before that, maintained a high 40s temp, but lasted only one season -- field mouse got in the back and shorted it out. An indoor fridge might work on a covered/screened porch, but I wouldn't risk one outside.
    30k gal IG SW gunite pool, 4-8' deep w/ 16" baja shelf; Ocean Blue PebbleSheen; well water (resin softener); Hayward Pro-Grid 7.5 lb., 60' D.E. filter; Hayward TriStar VS filter pump; Hayward TurboCell T-15 SWG; AquaCal TropiCal heat pump; Hayward OmniLogic automation, Colorlogic lights (2 large; 2 accent); Polaris cleaner w/ booster pump; TurboTwister slide (gray granite); 5' rock waterfall w/ second Hayward TriStar VS pump; TF-100 test kit
    rajung's Avatar
    Mar 2015
    Iowa
    284
    I have the EdgeStar OBR900SS, it is outdoor rated , not sure what I paid for it 3 years ago, but current prices look to be 650.
    About 2x the price of comparable indoor unit " size wise".
    I think when deciding to go with a outdoor rated unit for a fridge, its unlike a indoor tv being used covered, outside.
    This fridge is all closed and stainless. The only time it sweats is in extreme high humidity, the kind where you cant breath, and only the glass on door . It is on our covered deck, so its shaded. I place on deck in April /May and it runs continually until we start to put items away in the fall. Never failed and it keeps items at 36-38 deg.I don't think it ever went over 40 even in the hottest days. Only one problem with this unit is the lower pivot pin for the door, if it even is a pin, not sure. it must be made of un- treated metal because after the second year it started to leave a rust spot on deck floor right below it, about the size of a penny, so no big deal.
    Unlike a standard tv outside, which I use, this might be a money saver in the short haul.
    Doughboy AG 16' x 32' oval, 13,700 gal.
    AquaView by Doughboy 150lb sand filter model 0-1709-20
    PowerLine pump by Doughboy model 0-3047-200, 1.5hp-single speed-20amp
    Gulfstream electric heater-HE125-R-A
    Taylor K-2006 test kit
    I installed a small outdoor fridge from Bull
    Mod Squad pooldv's Avatar
    DFW, TX
    24,976
    We've had a regular old side by side fridge on our screen porch for years. We also have a 1950s era fridge on the screen porch of a cabin in Missouri that has been there for decades.
    There are plenty of beer fridge pics on my pool thread, link in sig. Here's one.
    Attachment 74079
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,471
    TheEngineer I think it would depend where you place your fridge. I have a small 2.6 cub ft home mini fridge in my summer kitchen however the sun only shines on it for a couple of hours 12-2pm each day. Our kitchen is protected from the elements so we are happy so far with our regular fridge. Look at our summer kitchen build New Outdoor Summer Kitchen in the Dolphin Bar and Grill in the sig bar
    6,000 gal, IG free form,Beach Series Antigua by Marbletite Pebble finish,Sheer Descent, IG Fountain, Dolphin / Mermaid Statues,Dura- Glas 1.5hp pump,Hayward Pro-grid DE4820, Aqua Rite SWG with T-Cell 15,Heat Siphon Heat Pump DX 5.0 109,000 btu, Pool Cage, 1800sq ft Tremron Estate Pavers,Aquatherm Ecosun Solar Panels 192 sq ft with GL-235 Controller,Pentair IntelliBrite, Apollo Magnetic Stirrer Our New Poolbuild, Jacksonville, FL yr 2009 Solar install Outdoor kitchen upgrade
    PoolguyinCT's Avatar
    Jul 2014
    Connecticut
    2,591
    A couple summers ago, I had an outdoor fridge
    Installed between my breezeway & kitchen door..
    I always enter through the breezeway...
    My biggest advice is to keep water bottles stocked, I was hung over for the first month.
    Azmp1's Avatar
    Jul 2012
    Maryland
    295
    I have a $100 and change Danby mini fridge, that sat in my non-air conditioned sunroom for about 6 years. I would turn it off for the off-season, so it only worked for about 7 months out of the year, but it did like a champ and for pretty hot inside that sunroom. Now, as we moved, I'm planning to use it in the outdoor kitchen, so we will how it will do.
    But, here's my view on this. You can easily buy a standard mini fridge for a about $100. Let say, even if it lasts me 2 seasons, and I Have to spend $100 to buy a new one every two years, it will take 6 years to reach $300 that will the cheapest outdoor fridge cost me.
    32000gl freeform gunite/diamondbrite perl pool || Jandy Sheer Descents || Jandy variable speed 2hp e-pump & Polaris PB4-60 booster pump || Polaris 3900 sport cleaner || Jandy CV filter || Jandy AqualinkRS6 w/Aqualink touch || Jandy iAqualink2.0 || Pentair Intellibright LEDs || Jandy AquaPure 1400 SWCG || Hayward auto chlorinator (backup) || Raypak 140k BTU heat pump
