Thread: Harmful to switch switch multi-port dial while pump is on?
    May 2017
    Lexington, SC
    144
    Do I need to switch the pump off before changing the setting on the multi-port?
    Thanks!
    Jun 2016
    boiling springs, SC
    99
    Re: Harmful to switch switch multi-port dial while pump is on?
    Yes very much so. If you switch the valve while pump is running it could blow the seals out or run up pressure an pop a fitting.
    23,000 in-ground salt water pool with liner, 1.5 HP 2 speed Pentair pump, Hayword C4025 cartridge filter, Jandy SWG.
    May 2017
    Lexington, SC
    144
    Yikes....good to know. I've only done it once before I realized that I shouldn't. Hopefully didn't hurt anything. I was just thinking it would keep the IntelliFlo from having to prime and spin up to 3,450 rpm each time I wanted to switch the multi-port dial. But now it makes sense why that's not a good idea. Speaking of the IntelliFlo spinning up to 3,450 to prime (and maybe this should be another thread). Is there a reason it needs to spin up to the max RPM to prime or can/should I configure it to be less when it primes?
    Jun 2016
    boiling springs, SC
    99
    I would make a new thread as I donít know about VS motors I only have 2 speed
    May 2017
    Lexington, SC
    144
    Quote Originally Posted by callahan3 View Post
    I would make a new thread as I don’t know about VS motors I only have 2 speed
    Just made a new thread...thanks!
