Common story here...Moved into home 3 months ago with a pool that was completed in 2016. Water was and has been crystal clear the entire time along with strong chlorine smell which has now dissipated throughout the winter. Fusion Nature2 Chlorinator has been set on "6", highest setting, since we moved in however I have not added any Trichlor tablets and it is now empty. When tested in the past with a cheaper test kit, chlorine levels were high so I did not add any additional chemicals.
Fast forward to the past few weeks after discovering the TFP website. I have read all the articles in the pool school. Have purchased a Taylor K-2006C test kit and ran all the tests. Here's what I discovered:
FAS/DPD test FCl: 11.4 however when checking combined chlorine, I got nothing
CYA: was very high in fact used only 2ml from vial (a few drops) after mixing and I could no longer see the black dot on bottom of test tube
pH: 8.0
TA: 150
Calcium: 625
My theory is the CYA is high from using the Trichlor tablets which was set on the highest setting for chlorination for who knows how long. The calcium is high because we are on a well and that has also led to minor calcium scaling around the water features.
Question is what is the first step here to getting things going in the right direction and what concerns should I have? Appreciate the guidance anyone may have to offer.
Brock
Ft. Worth, TX
pH: 8.0
TA: 150
Calcium: 625
Brock
Ft. Worth, TX
