Thread: Pentair IC60 connections
    Mar 2013
    TN
    181
    My incoming connection on my SWG has cracked because somebody tried to take it off during cold weather. Anyway, the question is, is the 2" fitting on the SWG just a standard schedule 80 2" union like you can get at home depot or Lowes?
    20x49 double roman 3.5' to 8.5 deep', 44,000 gal. SWG, TF-100 test kit with speed stir, concrete walls with vinyl liner, cartridge filter on an IG pool with a 1hp main pump and 1.5hp booster pump. Pool built April 2013
    JoyfulNoise's Avatar
    May 2015
    14,225
    Re: Pentair IC60 connections
    No. They are specially sized custom fittings. You’d have to order replacements if a local pool store doesn’t have them in stock. Sadly, they are marked up in price quite a bit.
    Matt
    Mar 2013
    TN
    181
    Thank you, just order a pair of them. And yes they are marked up pretty good!
