I have a Jandy SHPF 1.0 pool pump that is making a loud noise when running.
This pump was here before we moved it. It did work fine until it recently started making the loud noise.
I suspect it is the bearings in the motor causing this but that is just a guess.
I would like to replace the motor with a variable speed motor if possible.
How do I find out what replacement VS motor will fit this pump?
What is recommended if there is any choice?
I found the user manual for the pump here:
https://www.jandy.com/~/media/zodiac/global/downloads/h/h0573800.pdf
Is there any way to confirm replacing the motor will fix this noise without taking it apart?
Could it be the impeller or something else?
Any other recommended part replacement if I am able to find a motor replacement?
I think this was manufactured in 2006 based on serial #.
Eventually I would like to do automation but I do not have that setup yet.
I am attaching pics of the pump.
