Results 1 to 19 of 19
Thread: 3/4 hp single speed pump selection
    uxbridgechris's Avatar
    Jan 2018
    uxbridge, Ontario Canada
    560
    So what is your favorite brand/model and why? This will be for my 6000 gallon FB inground pool build. I have desperately wanted a variable speed but it makes absolutely no financial sense in my application.
    So, Tell me your stories and share experiences. Please!
    Blue Hawaiian “Wellington” FG pool 6500 Gal. Raypak 266 NG Nickle plated, 3/4hp Hayward super pump, Heater Reader wifi / app controller. Pentair 420 sq' cartridge filter. Hayward 25k SWG
    Pal LED pool lighting. Jandy K-1100 Electronic Autofiller Build thread here: 2018: Fiberglass install uxbridge ointario
    mas985's Avatar
    Pleasanton, CA
    12,049
    Re: 3/4 hp single speed pump selection
    What about a 2 speed? They usually run a bit less in terms of cost vs a VS. Here is an up rated 1 HP two speed:
    Amazon.com : Pentair 340042 SuperFlo High Performance Energy Efficient Two Speed Pool Pump, 1 Horsepower, 230 Volt, 1 Phase - Energy Star Certified : Swimming Pool Water Pumps : Garden Outdoor
    But given the cost of a new build, why do you say a VS makes no financial sense. It isn't much of a increase given the money you are already spending.
    Mark
    Jan 2018
    560
    Hahaha. I knew you guys were gonna try and sell me!!!!
    I just don’t see any point. There will be very little return on investment. Before I get too deep, the nail in the coffin for vs is due to the automation system I chose. It only works with single speed pumps. It is a simple system and that’s how I want to keep it. Also, in Canada I can get a 3/4 hp for about $450 Canadian. Vs pumps are 3 times that. But again, I’m kinda set on this automation system.
    cfherrman's Avatar
    May 2017
    Hays, Kansas
    1,707
    1/3 or 1/2 hp should do you, at that wattage single speeds are cheap
    Casey
    Intex 24' x 52" closed for winter 2018, 2 Main Drains, 1 Skimmer, 1 Return, PVC
    1/2 HP Intex Pump 633T w/ Taeglus TA-40 175 lb 19.5" Sand Filter, Auqabot Extreme Robot
    TF-50 and Taylor 2006 Test Kits, Quality Well Water, Fleck 5800SXT Water Softener
    Jan 2018
    560
    Cheap to run you mean? Yes.
    So what brands guys?
    mas985's Avatar
    Pleasanton, CA
    12,049
    Hayward, Pentair, Jandy. It doesn't really matter. Reliability in pumps is primarily dependent on the motor and not the wet end. But pump manufactures only make the wet end and use motors from motor manufactures.
    Mark
    Jan 2018
    560
    and I doubt they use American made Leeson or Baldor right.
    mas985's Avatar
    Pleasanton, CA
    12,049
    Nooo! Emerson, Nidec (US Motors), Regal-Beloit (AO Smith/Century). Pretty much all are made in China or Mexico these days.
    This is a good pump:
    Pentair SuperFlo 1/2 HP Single Speed Pump - 340036 - INYOPools.com
    But you can get a two speed with the switch in the back for a little bit more:
    Pentair SuperFlo 1 HP Dual Speed Pump - 340042 - INYOPools.com
    Running on low speed would save about 75% in energy costs. You will easily make up the cost difference in a season or two.
    Mark
    Jan 2018
    560
    Look at what we pay in Canada. Lol
    cfherrman's Avatar
    May 2017
    Hays, Kansas
    1,707
    Looking on that site, the cheapest pump was $350-$400 and the cheapest 2 speed was $530. The $350 pump was 1 hp.....
    Casey
    JoyfulNoise's Avatar
    May 2015
    14,225
    Drive 2hrs to Buffalo, buy a pump, put it in the trunk under some luggage and loose clothes and save some money....
    Matt
    Jan 2018
    560
    Take a day off work, Drive 2 hours, at $6 a gallon. Buy in us funds @ 30% exchange rate. Pay 13% duty at border. Drive home at $6 a gallon. HahAhahahaha
    cfherrman's Avatar
    May 2017
    Hays, Kansas
    1,707
    2 hrs at 60 mph I guess, 120 miles X2, 240 / 15 mpg x 6 = $96
    $300 pump , I guess x 1.3 = $390
    Add 13% = $50.70
    = $536
    Fun times crossing the border, priceless!
    Fill up in the us side for $3 a gallon, bring a drum!
    Casey
    May 2015
    14,225
    That’s why you put the cut-out under the backseat. It’s where you put the US merchandise. When asked what you did in the US you respond “visiting friends”.
    Can’t help you on the gasoline. You guys simply pay way too much for it.
    Matt
    Jan 2018
    560
    I don't lie to border guards. They will flag me and every time I cross it will be a 2 hour ordeal.
    I just ordered my pool lights from the US as they were not available in Canada. $1200usd. my PayPal was charged just under $1600 Canadian and when Mr UPS gets here, I will have to hand him 13% on the 1600. lol
    life is good
    mas985's Avatar
    Pleasanton, CA
    12,049
    Isn't the difference in price just a reflection of the exchange rate?
    This pump is listed as $339.99 on a US site:
    Pentair SuperFlo 3/4 HP Single Speed Pump - 340037 - INYOPools.com
    The same pump is listed as $429.99 on a CA site:
    Pentair 3/4 HP SuperFlo Pump Ingroun - Pool Supplies Canada
    The ratio is 1.27 which is actually a bit lower than the true exchange rate so the CA pump is a slightly better deal. Although shipping might be different.
    Mark
    Jan 2018
    560
    It depends on many factors I am sure. When exchange rate was at par consumer goods were still 10 -20% higher here.
    With the exception of a few things like beer. lol. I think it's around $50 for a case of beer and that doesn't improve with a strong dollar.
    May 2015
    14,225
    $50 for beer
    Forget the cold and snow, I’d never survive the sobriety....
    Matt
    Jan 2018
    560
    ya. the people at your walmarts taking a selfie with the stack of beer and the $14.88 sign........They are Canadians. lol
