Thread: Tds testing
    Jun 2014
    Newporr,ca
    47
    Tds testing
    Can i test my pool for TDS with the Taylor K2006 Pool Water FAS-DPD Chlorine Test Kit?
    1500 gallons SPA. 104
    IG, Plaster, 6years old.
    Sand filter Triton ll TR140.
    Taylor K-2006 Complete Pool
    Pentair brominator feeder using bromine. Bi-carbonate. Calcium chloride.
    JoyfulNoise's Avatar
    May 2015
    14,225
    Re: Tds testing
    Quote Originally Posted by whitemok View Post
    No. TDS is unnecessary and meaningless. If you need to know a specific chemical level, there are drop tests for every common component of pool water. TDS tells you nothing specific.
    Matt
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,873
    Re: Tds testing
    Matt,
    I pretty sure it tells the pool store to try and sell the customer some more "magic"...
    May 2015
    14,225
    Re: Tds testing
    Well, if you just have to know what TDS is, this is how you calculate it -
    TDS (in mg/L) = (0.6 x adjusted TA) + [CYA] + [Na+] + [Ca2+] + [Mg2+] + [SO4 -]+ [Cl -]+ [NO3 -] + [NO2 -] + [NH4+]
    You can ignore the ammonium and nitrite because those would not be found in a properly chlorinated pool. If no dry acid is used, then ignore the sulfates. Magnesium can be calculated by running the CH hardness test twice - once with R-0010 and once without then subtract the two. One can use the K-1766 to determine salt level which would be [Na+] + [Cl-].
    Matt
    cfherrman's Avatar
    May 2017
    Hays, Kansas
    1,707
    Re: Tds testing
    Yeah, take a $100 bill and rip it up in small peices, throw in pool, count pieces that sink. That is your TDS
    Casey
    Intex 24' x 52" closed for winter 2018, 2 Main Drains, 1 Skimmer, 1 Return, PVC
    1/2 HP Intex Pump 633T w/ Taeglus TA-40 175 lb 19.5" Sand Filter, Auqabot Extreme Robot
    TF-50 and Taylor 2006 Test Kits, Quality Well Water, Fleck 5800SXT Water Softener
    Jun 2014
    Newporr,ca
    47
    Re: Tds testing
    Ok thank you
