Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: Dolphin Premier vs Dolphin Nautilus Plus
    Dr. Hops's Avatar
    Feb 2015
    Canton, GA
    32
    I have a 14 foot by 33 foot fiberglass pool and am considering buying a robotic cleaner to replace the pressure side cleaner. I found a Dolphin Premium (s300i) for $700 refurbished and a Dolphin Nautilus Plus refurbished for $600. Those of you with either one, is it worth the extra $100 to get the Premium? Iíve looked on this forum and online and seems the only real advantage is to the Premier is the Bluetooth.
    Last edited by Dr. Hops; 03-01-2018 at 09:32 PM. Reason: Sorry, actually meant Premium, not Premier
    bmoreswim's Avatar
    Jul 2012
    Central MD
    4,231
    Re: Dolphin Premier vs Dolphin Nautilus Plus
    From Poolpartz.com I presume? I see the prices you listed. They are differently designed machines. The Nautilus Plus is an older model which has two separate and smaller debris collection areas, versus a single larger one on the Premium.
    That's a very good price (for a refurb.) for that model - Premium. Every now and then there is a model on there that is more discounted than other models relative their full retail price. My Active 20 was $499, whereas now it is shown at $699.
    Personally if you are OK with the refurb. I'd get the newer tech Premium at that price.
    One item to note, those models are not current year, so won't have the newly added 2018 swivel cord to reduce/eliminate cord twisting. But hardly worth hundreds more to get that one feature.
    For others, here's the link.
    https://www.poolpartz.com/dolphin-premium-refurbished
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Jun 2016
    NE/Pa
    1,696
    If u want the swivel there is a M400 there. It’s a 17 model with Bluetooth. No remote. Just app control. I think that one referred is not a bad deal
    TFP - Come for advice, stay for the education, leave with knowledge -
    35x23/20 free form gunite 3.5-6 feet water. 20,000 gallons. 2 skim, 2 ret, floor ret, floor return. 2 inch solid. suction cleaning line. 1.5 inch solid. super blue diamond brite. NPT Gemstone Blue 2x2 with custom Disney Mickey markers. pentair equipment. master temp 300,000 BTU. de 60. inteliflo 3.0 VS. swg ic40. 3 globrite LED's. ET 4/SL. tf-100/ salt kit
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,883
    Doc,
    Not to be picky but the Dolphin Premier is an older unit and not at all like the S300i... The link is for a much newer unit the Dolphin Premium....
    I have the Premier, and it works great, but I'd trade it for the Premium in a heart beat...
    Thanks for posting,
    Dr. Hops's Avatar
    Feb 2015
    Canton, GA
    32
    Jim R. My mistake. I meant Premium, not Premier. I went ahead and ordered the Premium. Thank you everyone for the advice!
    Jun 2016
    NE/Pa
    1,696
    So when u say premium which one in the line? The m series build or a s series (active) build. Cause dolphin labels premium for the top of the line for each line. M500 premium. S300 premium.
    Its so confusing.
    Dr. Hops's Avatar
    Feb 2015
    Canton, GA
    32
    bmoreswim's Avatar
    Jul 2012
    Central MD
    4,231
    Itís the same as an S300i. The link above will give you the visual. All of the Sí twins have an identical profile, just different color schemes.
    Dr. Hops's Avatar
    Feb 2015
    Canton, GA
    32
    Hereís the link. Dolphin Premium - Refurbished
    Jun 2016
    NE/Pa
    1,696
    Quote Originally Posted by Jimrahbe View Post
    Doc,
    Thanks for posting,
    why in a hardbeat? It seems like ur model with 3 brushes and how it collects waste is more functional than the 2 brush design of the s line active line. Ya bigger basket for collecting but less brush for cleaning. Also I think the pressure movement to climb looks awesome but don’t know how it would handle in real life. The nice thing is the s300 or active 30 is a lot cheaper it seems compared to the M500 or even 400.
    im just trying to learn.
    Jul 2014
    Bedford, TX
    9,883
    Quote Originally Posted by jimim View Post
    My Dolphin Premier only has two brushes and relatively small "baskets"....
    Here is a link to mine... Dolphin Premier Robotic Pool Cleaner | PoolExpress
    Jun 2016
    NE/Pa
    1,696
    I thought all those designs had 3 brushes. I thought that model was just a M400 pretty much so 3 brushes. I didn’t know.
    Why does dolphin make these diff named models. And make the littlest changes in them. It makes no sense. 1 line to all deals. Why same pieces with diff lines to diff dealers. It’s actually stupid I think.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    4,231
    GM did it for years with 5 brands and we see how that turned out. Maytronics produces them for different sales avenues. Just marketing folks trying to keep themselves busy and create more sales. You can argue if it is a good strategy but it does seem to give some better prices if one looks carefully versus if there was just one model to choose from. But, yes, very frustrating and confusing. That and marketing material could be clearer for sure. They also have no real incentive to compare them for you.
    Dr. Hops's Avatar
    Feb 2015
    Canton, GA
    32
    I ended up getting the Dolphin Premium and couldnít be happier! The first cleaning and the pool looked great. I took other peopleís advice and brushed everything off the steps, the ledge and the benches and brushed it all away from the walls. The pool was immaculate afterwards. If the water wasnít so cold I could have gone swimming! What used to take me several hours and hundreds of gallons of water took Hydra (my son named it) a few hours and zero water while I sat in the house and watched tv. I just wish I would have bought one years ago!
    bmoreswim's Avatar
    Jul 2012
    Central MD
    4,231
    So glad to hear it!!
    JoyfulNoise's Avatar
    May 2015
    14,226
    Dolphin/Maytronics does not sell directly to consumers - it would require far too much infrastructure and resources poured into a very small market making it an unprofitable business for years and years. So, in order to sell their product in the US market, they use wholesalers and retailers as their distribution channel. As such, those wholesalers and retailers demand certain restrictions, features and warranty items that forces Dolphin/Maytronics to fracture their product line and create competing units that are essentially equivalent. If they did not do this, then retailers would refuse to sell them as there would be no or little profit to be made. This is one reason why online sales are so restricted - retailers could never compete with equivalent units being sold on Amazon or eBay and so there has to be a huge disincentive to buying them through those channels. This has the unfortunate effect of keeping prices artificially high and, unless a competitor comes in with a similar product that is equally well-engineered, consumers will simply bear the cost.
    Monopolies are terrible unless you’re the guy that owns the monopoly....
    Matt
    lightmaster's Avatar
    Jun 2017
    Baxley, GA
    799
    I'm thinking about buying a Dolphin this year, what's the disincentive to buying one online?
    Pool Stats: 18' X 48" Vinyl AG, 6,700 gal, Hayward Power-Flo LX 1hp and Easy-Clear C400 cart, Circupool RJ-45 SWG, Dolphin S300, My AG Pool Mods
    Helpful Links: Pool Logger, PoolMath, TF100 test kit, Recommended Chemical Levels, Ext Test Kit Directions, FC/CYA Chart, Chlorine Date Code Calendar, Polyfill Iron Removal, Borates Drop Test
    May 2015
    14,226
    Quote Originally Posted by lightmaster View Post
    Unless otherwise stated by Dolphin, all online sales void the warranty.
    If you’re thinking about getting a robot, check out Marina’s Pool & Spa or Doheny’s. You can see what they have online and then order over the phone which counts as a “brick & mortar” sale. If you’re willing to buy a refurb, then the site mentioned above is one that is used a lot for refurbs. Think about buying locally of you want access to a local repair shop. Some shops will refuse to repair (even under warranty) robots that they do not sell directly.
    Matt
    Are you sure about the no warranty online? Amazon listings show a 12 month warranty. I did notice that a local pool store that he was selling the ECHO and it has a 24 month warranty on the brochure. Dolphin has so many models its confusing. Online for the same money it looks like you get more features with a shorter warranty for the same price for something in the store.
    10,000 I/G PebbleTec Pool, !.5 HP Hayward Super II Pump w/ imPower Motor, 175 sq FT Hayward Cartridge Filter, Jandy Aquapure 700 SWG, Zodiac G3 Cleaner, HydroTemp Heat Pump, Fiberstart Fiber Optic Lighting
  20. Back To Top    #20
    May 2015
    14,226
    Quote Originally Posted by bonubby View Post
    I believe Dolphin has one model that they allow for online sale and it’s a very basic, no frills unit. If you do purchase it online, I’d call up Dolphin and confirm. Sometimes you can extend it with a Square Trade warranty or a credit card warranty program. The Echo is essentially the S100 with minimal features. None of the higher order models are allowed to be sold online. eBay and CraigsList definitely voids all warranty.
    Matt
