Thread: Cloudy/milky water...
    May 2017
    Houston, TX
    8
    Hi everyone. Over the last two weeks, there has been a lot of rain here in Houston (well, more than two weeks) and a lot of pollen got thrown into my pool. It turned green, so I brushed it and put some shock (the one with CYA) yesterday. It looks much better, but I noticed that it was very foamy when I ran the pump, and today it looks cloudy/milky. I just tested the water and here is what I have:
    FC 5
    CC 0.5
    pH 7.4
    CH 290
    TA 70
    CYA 60
    The pool has no shade, it's very sunny most of the year, so I think CYA @ 60 is good. Let me know if you think otherwise. I usually put liquid chlorine to maintain FC levels. Any thoughts on how to get crystal clear water? Are my numbers satisfactory to result in crystal clear water? Any suggestions as to my next steps would be appreciated.
    Thank you.
    triptyx's Avatar
    Apr 2016
    1,485
    Re: Cloudy/milky water...
    I'd start with an Overnight Chlorine Loss Test to see if you're dealing with algae. Rain doesn't cause milkiness.
    Pool School - Perform the Overnight FC Loss Test (OCLT)
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
    cfherrman's Avatar
    May 2017
    Hays, Kansas
    1,707
    You fc is at the minimum for your cya
    Casey
    Intex 24' x 52" closed for winter 2018, 2 Main Drains, 1 Skimmer, 1 Return, PVC
    1/2 HP Intex Pump 633T w/ Taeglus TA-40 175 lb 19.5" Sand Filter, Auqabot Extreme Robot
    TF-50 and Taylor 2006 Test Kits, Quality Well Water, Fleck 5800SXT Water Softener
