Thread: Hayward Aqua Plus panel placement. Why not put it IN my house?
    Dec 2017
    Culpeper, VA
    15
    I am (hopefully) going to do a DIY pool in Mid-April. I have been talking with the local permit folks / inspectors.
    I plan on using the I plan on using the Hayward Aqua Plus for SWG and for some minimal automation. I have reviewed a thread that states I will need a 50 amp breaker in a subpanel, and a GFCI somewhere in there. If I put in the subpanel in the house, I need to run 6 gauge wire about 49 feet to get to where I was thinking of putting the Aqua Plus.
    Questions:
    1, is the Hayward Aqua Plus rated for "Weather Proof"? (Or is it going to be a big time breaker-tripper if I put it outside?
    2, Why don't I just make the Aqua Plus panel the subpanel, and mount it in the house? All I would have to do then is to run control wires, power to the pump, and power to the pool light in to the house.
    Pool: Poolwarehouse.com DIY Gold Coast kit. 18' x 39' x 8' deep. Hayward Aqua Plus SWG system. Water returns are two Aqua Genie skimmers and two waterfalls. Pump: Hayward Super Pump VSP.
    Re: Hayward Aqua Plus panel placement. Why not put it IN my house?
    It's ok outside.
    Why 50 amps? Unless you're running a heat pump, you don't need 50 amp service.
    The cell power cord standard is 15 ft but there is a 25 ft cord cell.
    I would put it by the equipment.
    Support the site
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,858
    Mug,
    The panels are made to be mounted outside near the equipment pad.. This is because the wiring from things like the salt cell, the VS Pump, valves, etc. are all only about 15 feet long. Does not mean you can't modify them, just more work...
    They will not trip any breakers because they are in an enclosure...
    The enclosure should have a load center built into it and this is where you would mount all the circuit breakers for the wiring going to the pool equipment.
    I also believe that there is an electrical code that says the shut off (Breakers) have to be within 15 feet of the pool equipment... You will have to check with your local officials to see if that is really the case, or just hearsay...
