Thread: To much air?
    Jun 2016
    boiling springs, SC
    99
    To much air?
    Air in my pump - YouTube
    Is this too much air? I can get divert to where itís only bring water from the pool at the bottom drain port and it almost goes away but if I split it from the basket it bring in the air? I took the floating part of the basket out still no help? Itís causing air build up in my filter.
    23,000 in-ground salt water pool with liner, 1.5 HP 2 speed Pentair pump, Hayword C4025 cartridge filter, Jandy SWG.
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,872
    Re: To much air?
    cal,
    That is too much air in the basket... Most suction side air leaks are caused by the following:
    Number one the most likely and number six the least likely..
    1. Water too low at the skimmers.. Water should be half way up the skimmer opening.
    2. Weir door (Between the water and the skimmer basket) stuck up.. The Weir should be able to float up or down.
    3. The pump lid O-Ring is not lubed or is damaged or missing...
    4. Air leak at pump input... the connection at the front of the pump is leaking air.
    5. The valve that allows water into the pump is leaking air.
    6. The pipe between the Skimmer and the pump is leaking air.
    Thanks for posting,
    Jun 2016
    boiling springs, SC
    99
    Re: To much air?
    what I know as of right now is:
    Water level is good. half way on skimmer
    I have no door on my skimmer just a basket.
    Pump O-ring good and lubed with magic lube
    it's the pump input that I need to check, the valve and for heavens sakes I hope it's not the pipe between the skimmer and pump.........
    Jul 2014
    Bedford, TX
    9,872
    Re: To much air?
    C,
    I assume it was working at one point, so when did it go bad? Did you connect a vacuum to your skimmer and after this the problem started?
    I assume your video was shot when the pump was in high speed... Does it look the same in low speed?
    What is your filter pressure and when was the last time you cleaned the cartridge?
    Cartridge filters can plug up very fast if your water is green and cause a similar problem.
    Asking a lot of questions, I know, but these are the things that I would look for if I was standing next to your pool..
    Jun 2016
    boiling springs, SC
    99
    Re: To much air?
    Yes the pump was high no air on low.
    Cartridge is new not a couple days old psi the same as installed
    10psi is the pressure
    I took apart the 3 way valve an see one o-ring that seals the Handel was flat at one part but thereís two o-rings? Iíll have to order a repair kit an hope this is the problem.
