Thread: Circupool rj45 plus vs rj60 plus
    Apr 2014
    louisville,ky
    37
    Hello,
    I am looking at going to the swg. Iíve settled on the the circuPool brand.
    My pool is a little over 24,000 gal.
    The price is $900 for the sj45
    and $1100 for the sj60. I know I would get longer life out of the bigger salt cell. But it is also more expensive to replace. Those that have went to these systems...what are your thoughts?
    Thanks
    24,200 gal IG vinyl liner. Sand filter 1 1/2 hp Haywood pump. T2 turbo pool cleaner
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,863
    Re: Circupool rj45 plus vs rj60 plus
    e,
    The only direct knowledge I have on CircuPool Salt systems is what I read here...
    If I did not have an automation system I would be temped to buy the Universal 40...
    I would think that the RJ45 would be enough for your pool, but bigger is almost always better..
    Let's see if we can get some of the CircuPool owners to chime in...
    BasicTek's Avatar
    Oct 2016
    Lake Mary, FL
    795
    Your title says RJ but your post says sj
    The RJ45 is actually $810 (choose 410 upgrade) and the RJ60 is $1010 if you actually want an SJ55 it's $759
    The RJ45 should produce roughly 10FC a day in your pool running 24 hours, depending on your FC demand if say 3 in summer you would need to run it 7.2 hours and as you stated it would not last as long and the RJ60
    The RJ60 should produce roughly 15.5FC a day in your pool running 24 hours so to produce the same 3 you should only need to run it 4.6 hours
    The SJ55 should produce 11.7FC in 24 hours so your runtime would be 6.15.
    These #'s are based on the manufacturers rated lbs. Your FC demand is probably less than 3 in KY but depending on various variables could be a little more in peak summer. So without a variable speed pump it would probably be best to pay a little more and have a shorter run time.
    -Tim-
    Pool: 86 gunite/plaster screened IG 12K 14' X 29', Hayward 120 sq ft cartridge filter, Pentair Intelliflo 2 VST, Hayward SwimPure 40K SWCG, Hayward Poolvergnuegen autovac,
    Heat: 280 sq ft Ultrasun solar Panels, Pentair Solartouch Ctrl, (solar cover and reel)
    Tests: Taylor K-2006C & K-1766 w/ speedstir
    Apr 2014
    louisville,ky
    37
    Yeah thx for the comments. I meant rj plus that’s why my price is different. They have a few more bells & whistles. Plus the warranty is two yrs longer. Just an FYI for those looking to go swg. The $10 free upgrade on circuPool salt systems ends today at midnite at Welcome to Discount Salt Pool - Saltwater Chlorine Generators - Chlorinators
