Thread: I need help deciding
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    Im looking into getting a SWG this year and I need help picking between three circupool models.
    The SJ30, RJ30, and universal 40 would all fit my pool just fine but I can't figure out if all the bells and whistles on the RJ model are worth the extra cost. Or if the universal is a budget way to get a cell 4x the capacity of my pool which should in theory last me a very long time.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    mas985's Avatar
    Pleasanton, CA
    12,046
    Re: I need help deciding
    The SJ30 design (inverted U) is one where the hydrogen gas collects in the cell if you operate a pump on low speed. Several people have had an issue with this and the cell eventually shuts off. Also, the clear plastic could possibly allow UV ignition of the hydrogen gas which I think I remember one person posting happened to them. You could invert the cell so gas does not collect in it but if it were me, I would go with the other design.
    Mark
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    Non exploding design is a good selling point.
    Chuck-
