Thread: New Spa jets not working well
    Feb 2018
    Nashville
    1
    I have a new spa just built. It has 20 jets. 10 on a hayward 2hp variable speed pump. Plumbing is 2-1/2" These jets work pretty well. The other 10 are run through the a cartridge filter and heater. These are doing poorly. They are also on a hayward 2 hp pump. We pressure tested lines and they are fine. These are on 2-1/2 lines as well. Can we upgrade pump size to 3hp and put an inline filter? would that help. There is probably about a 50 foot run of plumbing on this side as well with 90's etc.
    Help!!
    Nov 2011
    Moberly,MO
    1,036
    Re: New Spa jets not working well
    The restriction flowing through the heater is possibly a big part of your loss of pressure. The builder should of plumbed one return for circulation through the heater independent of the jets.
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
