Results 1 to 7 of 7
Thread: Adding SWG _ vertical installation?
    Jan 2018
    North/Texas
    58
    Attachment 73124
    I'm about to install the SWG to my system above. The plumbing on the right are my return lines....out from filter....valve...two pipes back down to pool.
    There is not enough room for the SWG to have the 12 inch recommended piping before flow switch and SWG plates. It looks like I'll have to cut all 3 pipes
    to extend them upwards 12 inches (ish). This would have my SWG being installed vertically, in essence, raising my valve up so it would still be horizontal.
    Anyone see any other means? or do you see any problems with a vertical install for the SWG?
    Thanks.
    20'x40' vinyl liner pool, 23K gallons, filter: Hayward DE 3600 4820, 1hp single speed 1.65 V-Green VS motor, Circupool RJ-45 SWG, 1.5 inch PVC, 2 skimmers/1 main drain, 3 returns and 2 bubble jets @ stairs, and a partridge in a pair tree. testing: K-2006, Salt; K-1766, Test Strips; Aquachek 7. calculator: PoolMath
    22,760
    Re: Adding SWG _ vertical installation?
    Read the manual for the swcg and if it warns about installing it vertically, I wouldn't.
    Looking a the plumbing, it appears that there may be a couple of ways to route the plumbing so that you could install the swcg horizontally.
    1. Cut the vertical piping out of the multiport valve outlet and loop the plumbing back toward the wall and then turn it up and back toward the 3-way valve. There should be enough room to install the cell there.
    ╔═══╫╫╫╫═════3-way
    ╟ . . . cell
    ══════MP╝
    2. Loop the plumbing under the MP back toward the wall and then up and toward the 3-way valve.
    ╔═══╫╫╫╫═════3-way
    ╟ . . . cell
    ╟ ..═══MP ╗
    This will increase the head a little, but it shouldn't hurt the flow enough to notice.
    Forgive my terrible ASCII drawings, but hopefully you get the picture.
    Jan 2018
    North/Texas
    58
    thank you for the install ideas. I would not have thought of that. The underneath path then behind and up wont work because of the backwash/exit pipe on that side, but the over the top, behind, up and forward will work perfectly. This will allow me not to have to cut the return pipes going back in the ground.
    Anyone: Since I will be cutting pipes and replacing / moving things, are there any other suggestions with pipe maintenance or new products I should consider putting in? I know the ol' saying, if it aint broke dont fix it, but with this install, i'm just curious if there may be something worth my while while i'm back there with all the supplies.
    Thanks again.
    Jan 2018
    North/Texas
    58
    So, I actually ended up going down, behind up, and back over to the return pipes as your #2 drawing depicts. #1 drawing I found wouldn't have given me enough space for my hand to properly turn my backwash valve and made it very cramped.
    # 2 worked perfectly! Thanks for the idea, appreciate it.
    Attachment 73280
    My SWG is a 2in threaded ring (blue circle twist things), for a 1.5 inch pipe. I would like to remove the SWG and have a straight pipe there (for winters and pool startup purposes), are there ways to put an extension pipe in placement of the SWG?
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,541
    Looking good!
    Most brands offer a dummy (some call it 'bypass') cell which has same fitting and distance, e.g. Starter Kit
    12k IG salt; glass beads in plaster; K-2006C, K-1766, K-1106 and CCL test kits; Pentair Eco800 1.2HP VS; Zodiac SWCG 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; Other family pools 10K SWCG and 15K on liquid; PoolMath app subscriber; | Tips for New Members to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    Jan 2018
    North/Texas
    58
    awesome thanks. Turned the motor on. no leaks in the plumbing.
    22,760
    Glad you could figure out how to get it installed. Looks like you can actually get to everything also.
