Thread: Some Jets Weak
    Some Jets Weak
    I have a 2003 Marquis Euphoria. See video below.
    IMG 3944 - YouTube
    You can see on low and high speed I seem to get more pressure and jet action on one side of the tub. Especially with the high speed pump. Is this normal? We had the high speed pump replaced few months ago.. maybe there is still an issue with the low speed now? Not sure. Or maybe it is an issue with a diverter valve. Any ideas?
    2003 Marquis Euphoria - 400gal
    Jun 2014
    17,827
    Re: Some Jets Weak
    JJ, I'm going to give your post a quick "bump" as it's been sitting for a while with no replies. If your issue still applies, hopefully someone with insight will be able to help. The season is starting to get active again, so there should be more eyes on the forum board. Thanks for using the forum, and have a good day
    Nov 2016
    Helena, AL
    227
    Re: Some Jets Weak
    How easily can you open up the frame and take a peek at the plumbing? Itís really hard to tell from the outside.
    Is there a diverter that controls the flow to those valves? Can it be adjusted?
    30k IG vinyl w steps , Pentair SuperFlo 342001 pump, StaRite Cristal-Flo sand filter T-240-BP1
    Hayward Goldline AQR15 SWG, Dolphin Premium (aka S300i) Robot
    Borates & TF100 test kit
    200 gal hot tub (that I completely rebuilt)
    Nov 2016
    Helena, AL
    227
    Re: Some Jets Weak
    It also looks like you donít have the same airflow in that corner... is the air injector open the same as on the other sides.
