My pool freezing temperature is set at 50 degrees and it just drives us crazy, every night the pump starts running and I can not take it anymore! How do I set lower the freezing temperature on Compool cp3600 controller Pentair which I guess is the older model?
Did a quick review of the manual for that controller (found online). The Freeze protection temperature appears to be set at 35F without the ability to change it.
However, you may need to calibrate your air temperature sensor. See page 31 of your manual.
