Thread: Dimmer on the bubbler
    Feb 2017
    houston, TX
    47
    My jacuzzi bubbler is too strong and causes alot of splash out. Right now it has a simple toggle switch like in the home. Can I put a dimmer switch on it to decrease the bubbler strength?
    New Plaster Feb 3rd, 2017, oval pool 13000 gallons, with 500 gallon attached waterfall Spa
    cartridge filter 5hrs/day, 1.5hp VSP, Skim Doctor 2.0, polaris 280 pool vaccuum
    LaMotte 2056 ColorQ Pro 7 Digital Pool Water Test Kit, Rola-chem Pool Autofill, circupool RJ35 SWG, k1766 salt test
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    34,989
    Re: Dimmer on the bubbler
    What about a valve to control the flow? A picture of this toggle switch might be helpful so we can see what you are working with.
    Kim
